Replacing brake pads
A-CL Totaled Member
My rear brake pads are shot, my mechanic estimated $290 parts and labor, using an OEM metal pad. Now I just looked up some pads, and looks to me the nice metal ones are $50ish a piece, so that puts parts at $100. Is there seriously 190 in labor involved (about 4 hours)? Seems like an awful lot, and im pretty sure ive seen on here they are easy to do. Its a 98 2.3 by the way.
A-CL Post Whore w/N2O
I was quote $260 from Criswell Honda in Germantown to install my front rotors (I have the dreaded '97 design). They're charging me 4 hours for the front (which is reasonable).
I believe the real actual time charged for the rears is about 2.5 hours (so say $162.50) [even if in reality it doesn't take that long]. That means your mechanic is charging you about $127.50 for pads!![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
The rears are pretty easy to do. Even if you buy the pads yourself and have your mechanic install them, it shouldn't run you more than $150 to $175 for installation (plus the price you pay for pads).
A-CL Totaled Member
Thanks dust, i know my mechanic is generally reasonable, but I need to call and ask for an exact price assuming they dont need to do anything extra. They wont touch aftermarket parts either, if they are installing it they are supplying it, which I dont really like. If they cant do it cheaper I'll go to the honda dealer or this other dude.
who got the best deal?
thats fucking ridiculous i guess is all where you live, my brother changed his brakes for hi 94 accord(my old car) for 30 bucks, i mean there must be some other mechanics around there shop around.
i just changed my rear brake pads today....for free!!! my boy works at an auto parts store which will remain nameless, he got me some high-quality pads for buy none, get one free. but you didn't hear that from me. i put them and my cross-drilled, slotted rotors on in about 2 hours.
CL Poser AKA Tool
to change your pads
to change out your pads it is generally the same with all hondas (and most disc brakes as well)
1. remove wheel
2. remove caliper sliding bolts (or unbolt caliper)
3. slide moving part of caliper off (or take off entire caliper) (suspend caliper with wire from spring)
4. pop pads out and springs (along with shims/anti-squeal plates) (remember the order and where everything goes)
5. depress the caliper piston into caliper (watch fluid in your reservoir and siphon out if necessary)
6. apply anti-squeal grease to shims and put in place along with springs and pads
7. slide over rotor
8. torque down all hardware bolts
9. torque down wheel nuts
10. check fluid again
11. take a test run
12. test e-brake (re-adjust if neccesary)
Each side takes about 20-30 minutes (if there are no pad relocation springs...which is a damn toyota thing to do)
1. remove wheel
7. slide over rotor
11. take a test run
A-CL Totaled Member
Changed the pads this morning. The wheels were kinda stuck, but kicking the bottom seemed to work nicely. Now I know my mechanic is full of shit because the pads have about 20% left but i was already in there so i changed them anyway. Plus their estimate of $290 wtf, AEM ceramic pads (really made by nissin, which is oem) were $55 shipped without shopping around, and it took less than 2 hours for someone who had never done it. Only took that long because I had to figure out why the wheels wouldnt come off. Survived the test drive, which included an emergency braking because someone thought the double yellow line was where you center your car on a two lane road. Thanks for the advice
Autozone have one for $16 a pair for normal pads with lifetime warranty and $40 a pair for the dustless metal pads and its lifetime warranty. I dont buy break pads anymore
Originally posted by damond
I dunno if the 2.3 and 3.0's are the same. But the rear calipers on the 3.0 requires you to turn the calipers instead of pressing it.
![Canada](https://acurazine.com/forums/images/smilies/canada.gif)
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
