removed decals, now shadows
ok guys, today i went to the store and got some goo gone. I heated up my declas with a hair dryer and sprayed some goo gone in the crevis. I took some floss and cut them off. I got all the tape off, now I have shadows, so I thot that was ok I'll juss wash and wax. well i washed and waxed. It's a lil better but I still have shadows, is there anything that I can get to get it all off?
Cold and patience will remove the glue. If you get it cold, it will ball up. If you use solvents like goo gone or goof off, you risk damaging the clear coat. get the metal cold, wipe it as clean as possible with a terry cloth then soap it, sponge it, wax on, wax off, buff and you are pimpin'. Use a solvent, and you will see the damage in direct sunlight or under intense halogen and or florescent lamps. It will look like there is a spot where something is missing... like a leasion on the paint.
actually i just recently took off my emblems off of my black CL. the best thing that i found was using Maguires Scratch remover. if that doesnt get it all off i went with Turtle Wax's Black Polish. It made it almost impossible to see the scratches and ghost effect. You can use rubbing compound and wax but i think that is far too much effort and the polish works great.
i just used goo gone. not too much tho, just enough to get the sticky stuff moving. after that, kinda just came off with a towl. MAKE SURE you clean the area afterm, that you used goo gone on, and then wax it
ok, well friday I will prolly buff it out with a combound. If that doesn't work I will go get some mcguiars scratch x or w/e that is. thanx for the help guys. All's I need now is to lower my shit, after I found out which kit I wanna use, and than the rear lip. And of course I nice and loud turbo!!!
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
