Remote Turn On
Old Dec 26, 2003 | 08:11 PM
Acura23CL's Avatar
Remote Turn On
I am installing an amp and subs in my 1999 2.3CL and I noticed that on the back of the stock head unit there is no place to put the remote turn on/off wire. What do I do?? Also, I was assuming that with this remote turn on feature it would eliminate the problem of the amp draining the battery when the car is off. Is this true?
Old Dec 26, 2003 | 10:29 PM
baka_t's Avatar
The movement has started
Well if you have the stock bose system i would get a wiring diagram and find where the stock remote turn on is. If not i suggest running a switch to it. The amp will not drain the battery unless its under a load. Before all the old soundstream amps had no remote turn ons. The main reason for the remote turn on is to turn the amp on after initial powerup to protect speakers from being blown due to signal goin to the speakers during inital powerup from the head unit. Its basically a protection feature but i would run one just incase. Also another idea if you do not have the bose system is to use a relay connected to the ignition on the stock harness so everytime the headunit turns on the amp does.
Old Dec 26, 2003 | 10:36 PM
baka_t's Avatar
Originally posted by baka_t
Well if you have the stock bose system i would get a wiring diagram and find where the stock remote turn on is. If not i suggest running a switch to it. The amp will not drain the battery unless its under a load. Before all the old soundstream amps had no remote turn ons. The main reason for the remote turn on is to turn the amp on after initial powerup to protect speakers from being blown due to signal goin to the speakers during inital powerup from the head unit. Its basically a protection feature but i would run one just incase. Also another idea if you do not have the bose system is to use a relay connected to the ignition on the stock harness so everytime the headunit turns on the amp does. Well if you have the bose heres the link to the diagram
http://public.fotki.com/dustbuster4/stereoampwiring/ thanks to dustbuster4
Old Dec 26, 2003 | 10:58 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
If there is no stock remote wire, you can hook it to the switched acc power. does the same thing.
Old Dec 26, 2003 | 11:09 PM
red99cl2.3's Avatar
who got the best deal?
ummmm i think u just gotta wire it to the power antenna wire.
Old Dec 27, 2003 | 12:14 AM
LCARUCA 97's Avatar
Trailblazer = SUCK
only if you want the amp to be on when you listen to the radio. Most decks power down the antenna when the cd player is selected.
Old Dec 27, 2003 | 06:49 AM
Acura2.3CL's Avatar
there is no power antenna on the 1999 2.3CL??
Old Dec 27, 2003 | 08:15 AM
Leon's Avatar
Since you're keeping the stock radio for you system, did you find out how you're gonna get signal into your amp?
Old Dec 27, 2003 | 09:31 AM
red99cl2.3's Avatar
there is an antenna and it turns on as soon as you turn the radio on, and leon thats a pretty damn good question didnt know the stock radio had RCA outputs???
Old Dec 27, 2003 | 10:01 AM
suXor's Avatar
Still trolling
It doesn't...
Old Dec 27, 2003 | 10:02 AM
suXor's Avatar
Still trolling
Use the yellow with white stripe/rings, at the amp for our turn on lead.
Old Dec 27, 2003 | 12:20 PM
Mike 350Z's Avatar
I use the fuse for the radio as the turn on, it stays on all the time normally, but I have a switch hooked up to it so I can turn the amp off if I want to.
Old Dec 27, 2003 | 05:53 PM
Leon's Avatar
Originally posted by chrisbpickering
It doesn't...
thats right, theres a special thing that you need in order to get signal into your amp, don't remember the name of it though!
Old Dec 27, 2003 | 06:18 PM
Mike 350Z's Avatar
I just tapped into the back speaker wires to get signal to the amp, and yes it sounds fine.
Old Dec 27, 2003 | 06:21 PM
Leon's Avatar
yes, that can be done, but not all amps have high level input, if his has it then he can do the same thing!
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Azonics
Sep 22, 2015 05:28 PM
GraveDigger
Sep 18, 2015 07:46 AM
Sep 17, 2015 09:01 PM
