Quick question on what screw I should be ordering
When I took my dash apart earlier this year I lost one of the two screws that screw into the bottom of the glove compartment and attach it to the rest of the car. I ordered what I thought was the right one, but it wasnt. So before I make that mistake again I figured Id see if you guys were a bit better at reading part diagrams than I am.
Here ya go:
Any Ideas?
Ref. Part Description Part Number Price Req.
001 LAMP ASSY., GLOVE... 34254-SW5-003 $14.85 001
002 BULB (12V3.4W) (D... 34295-SA5-003 $1.90 001
003 STOPPER, GLOVE BOX 66406-SA0-000 $2.37 001
004 RUBBER, GLOVE BOX... 66417-SA0-000 $3.87 002
005 STOPPER, GLOVE BO... 66418-579-000 $2.73 002
006 FRAME, GLOVE BOX 77110-SV4-010 $29.20 001
007 PANEL ASSY., METE... 77200-SY8-A00ZA $61.12 001
008 COVER, METER 77205-SY8-A00 $17.83 001
009 PANEL, INSTRUMENT... 77211-SY8-A00ZA $97.43 001
010 PANEL, INSTRUMENT... 77216-SY8-A00ZA $23.77 001
011 COVER ASSY., INST... 77300-SV1-A10ZF $63.72 001
012 COVER, COLUMN (UP... 77350-SV4-A01ZB $24.47 001
013 LABEL, IGNITION I... 77355-SG0-A00 $1.89 001
014 BLIND, COLUMN 77355-SV4-000 $12.25 001
015 COVER ASSY., COLU... 77360-SV4-A01ZB $80.15 001
016 RING, COLUMN COVER 77371-SV4-000 $7.50 001
017 LID, GLOVE BOX *N... 77501-SV4-A00ZF $40.67 001
018 BOX, GLOVE *NH1L*... 77502-SV4-A00ZB $64.30 001
019 STOPPER, GLOVE BO... 77506-SM4-900 $2.08 002
020 ARM, GLOVE BOX ST... 77508-SX0-000 $1.95 001
021 DAMPER, LOCK 77509-SM4-A81 $1.85 001
022 HINGE, GLOVE BOX 77510-SV4-000 $4.71 002
023 DAMPER ASSY., GLO... 77530-SV4-A80 $15.80 001
024 LOCK ASSY., GLOVE... 77540-SV4-003ZF $45.00 001
025 STRIKER, GLOVE BOX 77542-SV4-000 $9.03 001
026 BRACKET, STRIKER 77543-SV4-A80 $9.65 001
027 POCKET, COIN *NH2... 77750-SV4-A01ZF $30.22 001
028 BOLSTER, DRIVER KNEE 77893-SV4-A20 $62.62 001
029 BOLSTER, PASSENGE... 77894-SV4-A00 $37.98 001
030 SCREW-WASHER (4X12) 90107-SE3-000 $2.10 002
031 SCREW, TAPPING (4... 90123-SM4-000 $1.25 AR
032 BOLT-WASHER (6X20) 90139-SH3-003 $3.63 002
033 NUT, SPRING (4MM) 90302-SA4-003 $2.83 007
034 NUT, SPEED 90310-SB2-003 $1.72 002
035 CLIP, PILLAR GARNISH 90609-SG0-003 $3.70 003
036 CLIP, INSTRUMENT ... 90609-SL9-900 $0.38 002
037 CLIP, SNAP FIT 90666-SM4-003 $2.18 008
038 CLIP, SNAP FITTING 90666-SP0-A00 $2.13 002
039 CLIP, COIN POCKET 90671-SV4-A00 $2.62 002
040 GROMMET, SCREW (4... 91641-SM4-003 $1.90 001
041 BOLT-WASHER (6X16) 93403-06016-08 $0.73 004
041 BOLT-WASHER (6X16) 93413-06016-08 $0.73 004
042 SCREW-WASHER (4X12) 93891-04012-00 $0.52 002
043 SCREW-WASHER (5X12) 93891-05012-08 $0.52 005
044 SCREW-WASHER (5X12) 93893-05012-07 $0.62 002
045 SCREW, TAPPING (4... 93903-24380 $0.40 004
046 SCREW, TAPPING (4... 93913-14280 $0.40 AR
047 SCREW, TAPPING (4... 93913-14480 $0.40 AR
048 SCREW, TAPPING (4... 93913-24420 $0.40 002
049 WASHER, PLAIN (5MM) 94103-05800 $0.38 001
050 WASHER, SPRING (5MM) 94111-05800 $0.42 001
Here ya go:
Any Ideas?
I believe it's number 44 on that diagram but it's not too easy to tell. If you have something similar sitting around your house it will probably work just as well. You could even take one of the screws out of the console (such as one of the three under the cup holder) and use it as a replacement.
