Quick Exhaust question
Old Apr 15, 2008 | 01:22 PM
jfkhan's Avatar
Jhatt from Ludhianna
I Have the OEM exhaust set up and over the last 6 months has busted 2 sets of the intermediate pipe right where that spring covered with the steel meshing is...it appears to have just coroded away.....
my question is why is this steel meshhing with srping underneath is there in the first place and not a straight pipe???
if I want to keep oem setup can I still run a straight pipe in the intermediate section right after the CAT???
Where can I find one of these straight pipes...any links???
thankx
JFK
Old Apr 15, 2008 | 01:42 PM
dragon084's Avatar
1999 CL3.0
if you are running a 3.0, I have a "Test Pipe" if you want (cat replacement).
BUT, I think what your referring to is the flex pipe.
Of course you can do some piping after the cat, people usually go to a muffler
shop and get custom piping and most of the time when this is done, we use a
"resonator" to muffle the sound a little more.
Custom piping is anywhere from 50$ to 250$ or even higher,
all depending on if you have a solid relationship with the muffler man and if he tends
to be a rape artist with his prices or if he is just a quality dude when it comes to mandrels and welds
Old Apr 15, 2008 | 02:08 PM
jfkhan's Avatar
hi dragon084 i am running a 2.3cl.....what is a test pipe is it some thing that replaces the CAT....I just need a straight pipe with no flex steel mesh around cause thats where is corrods from and fails.....mine is making this growl every time you start the car or if it is idelling....
Old Apr 15, 2008 | 03:07 PM
dragon084's Avatar
1999 CL3.0
I'd check out the EGR valve and make sure your o2 sensor is properly working.
that shouldn't be happening.
Any muffler shop can weld on a simple pipe though.
Old Apr 15, 2008 | 04:38 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Def the flex pipe, sounds like u need to go to an exhaust shop. Don't do the test pipe they're ghetto
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
Billu99tl
Sep 13, 2015 11:30 AM
datadr
Sep 12, 2015 09:12 PM
Hau_nguyen91
Sep 6, 2015 12:53 PM
