question for those with aftermarket shift knobs
Old Aug 30, 2003 | 01:17 PM
green972.2's Avatar
after you installed the knob.. what did you do about the chrome plastic trim ring and how did you make the boot fit flush on the knob?
Old Aug 30, 2003 | 01:49 PM
xrunner86x's Avatar
A-CL Totaled Member
you can find some of this stuff in search. most people cut the ring off and used a rubber band as snug up as they could get it. i did that and wasnt pleased, so i got a momo boot and knob which screw together.
Old Aug 30, 2003 | 02:23 PM
klepto's Avatar
I used a differnt shift boot
Old Aug 30, 2003 | 04:53 PM
green972.2's Avatar
xrunner... was the rubber band showing?
Old Aug 30, 2003 | 06:14 PM
xrunner86x's Avatar
A-CL Totaled Member
its been a while but it think i shoved the bottom ring of the new knob down the boot, put the rubber band on, then screwed it together so it wasnt.
Old Aug 30, 2003 | 07:31 PM
dennis's Avatar
I used a zip tie with my greddy shift knob. It worked out well because when you put on an aftermarket knob, there will be more slack on the top of the shift boot. This is because when you take off the plastic ring, the shift knob will sit lower.
Just take a zip tie and fold of the excess material (inside) and tie it with a zip tie. It won't slide down becuase the stick widens toward the base.
Old Aug 30, 2003 | 08:59 PM
green972.2's Avatar
howd yall get the chrome trim off... cut it?
Old Aug 31, 2003 | 04:36 AM
xrunner86x's Avatar
A-CL Totaled Member
yea
Old Sep 1, 2003 | 06:47 AM
PSPEC's Avatar
7th Gear
You can upgrade the whole shifter and use a PSPEC tuning shifter and shift boot. Super clean. Looks like OEM but better.
www.pspectuning.com
obert
Dec 14, 2015 11:36 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
lland
Oct 4, 2015 04:47 PM
christopher1
3G MDX (2014-2020)
Sep 10, 2015 06:43 PM
HOWELLiNC
Sep 5, 2015 03:09 AM
