Quaife install info
Quaife install info
For those that ever want to install a limited slip differential....
I have the following info:
1: The bolts that hold the final drive on the diff are reverse thread. Have to remove the final drive to bolt it to the new diff.
2: The gear that drives the vehicle speed sensor has to be pulled of the old diff too. Bought a 3 jaw gear puller that worked fine. Couldnt get the gear on the new diff so I slowly had to heat it with a torch to enlarge it enough to slide in onto the new one.
3: (and most important) Two tapered bearings have to be pulled off the old diff. No gear puller in the world can get its jaws into the tight clearance between the bearing and diff. Ended up damaging one of the bearings trying to get them off. Had to order two new ones Mon. $60
Cliff notes: Buy/rent a gear puller. Buy/Borrow a propane torch. Buy two new bearings prior to attempting much easier.
I doubt that I'll need these instructions, but thanks for posting them.
BTW: Are you a mechanic by profession? You really know your stuff! I'm amazed at what you've been able to do with your CL!
I shouldve been.
Been joking with the girlfriend that she needs to support me so I can go back to school to be a mechanic.
Nothing like taking a 50% pay cut to do want you enjoy.
Was the install worth it? If/when I get the turbo for my 2.2cl I would like something to improve cornering and I hear that the Quaife LSD is the way to go. Ballpark, how many hours do you think it would take for a shop to install it?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by 972xghost
wow its seems like this place was really legit back then, i wish there were guys here doing LSD, turbo, and H22 swaps now. Cocoa is the only one that i know of.
they are bad ass, the lsd wont help unless your powering out of a turn.
but i wouldnt spend the money unless you ahd a shit load of power, since they are like 950 dollars and all
i'd wiat till you needed a new clutch then did this mod
(Mid-Atlantic)
(Mid-Atlantic)
Alright cool. Yeah the clutch I have is making some barely audible grinding noises and feels like it may go soon (~1 year). The car has 160,000 miles on it and I have no idea when the clutch was last replaced. I was just wondering when the LSD would be practical seeing as how I do not have a turbo yet. So I am assuming I should wait until after the turbo. Thanks.
Damn, well, yall get after me to search.
I'll open the question up to anybody then: Does anyone have any experience with the Quaife LSDs? If so how awesome/crappy was it? Thanks
U will want to rebuild your internals before you put a turbo on a motor with 160K miles on it. K? Bye
Im going to go the whole, "buy a junked f22b1 and rebuild it in the garage" route, 'cause I can't afford to be out a vehicle for more than a few days. Thanks for your concern though
Originally Posted by ShavedH22CL
My boy has quaife in his 93 H22A7 hatch. It is amazing, car is to fast.
Billu99tl
09-13-2015 11:30 AM
asahrts
09-04-2015 05:55 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
