problems araise again!!!!!!
well, last week i took a 450 mile road trip to lawerencrburg, tn to pick up a f22 complete motor for 200 bucks. main reason i got it was for the IAC, TPS, MAPS sensors but n e ways, the ack drove there with no problems, but the second i turned into the place, car started acting up. i figured that it need a break so i waited 30 min or so and took off back home. the acceleration sucks, you couldnt go WOT or it would die. once i hit the interstate, crusied at 80 all the way it was ok but couldnt do accelerate any faster. got it home check the codes adn says #1 o2 sensor so i changed it, now its saying tps. i am confused. talked to mechanic shop and they said it sounds like a fuel issue.
while i changed my o2 sensor, i kept hearing a humming noise and i followed it too the trunk, climbed in and listen to the fuel pump and it is humming. keys off, every 10 sec it hums for 5 sec. N e suggestions??
That sux bro, you're having nothing but problems with that. Definately sounds like your fuel pump is on the brink. Also could be your fuel relay
Originally Posted by froggystyle14
where is the relay located adn is it possible to remove the fuel pump with out dropping the tank as my hanes manual says
haha the fuel pump si right in the truck when i removed all the faberick and everything from my trunk there is 3 screws and thats it. you dont have to remove the rear seats. if its anything like a civic fuel pump me and my friend got a phillps head and took the 3 screws out then pulled the furl pump right up then took it out. it looks bassically the same as the one in the civic from the top but i have never removed mine.
i knew there was something missing in my trunk. a bottle.... who's red cl is that/ i need the trunk liner that was there.
i am testing the main relay right now, if it is ok, i guess i will replace my fuel pump
That is what I was talking about in the trunk, but if you look at the helms manual, it says that you can only get to the wires. I haven't removed it so I can't say for sure, but the helms says you have to remove the tank.
well i noticed the screws but in the manual it says that there are 6 bolts i have to take off under that cap with screws. ohh well i guess i will try it and see how it goes, if i can find my camera i might just do a wrtie up
bad news guys, that 3 screw cap in the trunk is just for the ssending unit for telling you how much gas u got. fuckin shit ..... time to drop the tank...... FUCK FUCK
Hate to be the bearer of bad news, but I knew I was right. G'luck froggy.
well i did test the relay and it is good. i did drop the tank adn it was not that bad of a job. now on the other hand, putting it back in there was a bitch. the fuel pump did fix must of the problems. I still cannot go WOT or it bogs down and wont accelerate.
sorry no write up on the fuel pump install, i used the hanes manual and it was accurate.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
