problem with engine...need help
Old Jan 14, 2002 | 04:44 PM
chiggacl68's Avatar
speed freak
last week my check engine light went on...for some reason which i dunno why it did that, i have 2.3 stick and every time i tried to gun it with the engine light on, i couldnt get above 4k rpms no matter wat, as if the rev limiter went down to 4k rpms or something...but after i turned it off and restarted, the light was still on but the reving problem was gone. i tried resetting my ecu by taking outthe negative battery terminal off...the light went off for like a day...and when the light came back on the first time driving it with the light on the reving problem came back again...someone said it has to do with my O2 sensor or something...hope someone knows wat might be wrong with my car...if u konw lemme know ...thanks
Old Jan 14, 2002 | 04:59 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
There's a two pin female connector under the glove box. Mine was attached to this big blue plastic thing. It'll take you a while to find it. I had to search and search for it. The wires should be red and grn/blu.
Use a paper clip to short one side out to the other and watch your check engine light. It will flash slow then fast. The slow numbers is the tens digit and the fast are the ones digit. i.e. slow slow fast would be 21.
Let me know what the code is and I'll look it up in my manual. 61 is the primary O2 and 63 is the second O2 sensor.
Old Jan 14, 2002 | 05:11 PM
f0de's Avatar
Ham Sandwich
or you could invest in an obd2 reader and really know whats up
Old Jan 14, 2002 | 05:14 PM
RidinLow's Avatar
Scooby Guru
Cool, didn't know about the shorting the plugs trick... but then again, I'll just use my OBD2 scanner.
Old Jan 14, 2002 | 05:20 PM
chiggacl68's Avatar
speed freak
arent those obd2 scanners expensive?...someone lemme borrow theirs haha.... hey niedejb where do u see the digits from and how would u set it anyways, well if u have aim hit me up if u can help...its the same as this...thanks
Old Jan 14, 2002 | 05:50 PM
niedejb's Avatar
Where do you get an OBDII scanner?
Old Jan 14, 2002 | 06:03 PM
f0de's Avatar
Ham Sandwich
mechanic magazines have em.. heh.. i just use the one at my shop tho
Old Jan 14, 2002 | 07:01 PM
RidinLow's Avatar
Scooby Guru
Try www.obd2.com, www.obd-2.com, and other sites that pop up if you search for obd2 scanners.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
