Pro kit question!!! A.S.A.P.
I talked to a guy from a shop about lowering my 98 3.0CL with the eibach pro kit and he said that i dont want just the springs....that i need struts too...he said if i dont get the struts too my stock ones will blow out? is this true? does n e one else have just the pro kit springs? if so please respond with any input...i like to hear various opinions...Thank You!!!
Yes completely true. If you searched around a little, you would have seen this. The stock shocks not on;y give you a shitty ride with springs, but will die, depending on their age. I have also heard that if you ride on stocks for too long, the springs can become fully compressed and get ruined. But here are your alternatives: Koni yellows, KYB AGX's or Tockicos. These are all for the 94-97 accord but will fit the CL's. Those are going in order of price, and expect around $300 for the KYB's, which most people here have.
agreed. i also reccomend koni yellows. if u got $500 they are worth it. u can crop the car another .4 if u set them on the lower perch and they are fully adj up top for firmness.
look how low my car is with pro kits not sportlines
Originally posted by joeshmoe
It's also cheaper to install both at the same time.
so if your going to lower...you need shocks and struts.....(what if you go the coilover route??
I was thinkin Groundcontrol Coilovers (with eibach springs....then do i need struts?)
Originally posted by VXCL
[B]agreed. i also reccomend koni yellows. if u got $500 they are worth it. u can crop the car another .4 if u set them on the lower perch and they are fully adj up top for firmness.
Re: Pro kit question!!! A.S.A.P.
The fact is, the pro kits are not that much stiffer than stock, nor do they lower ride height that much for it to casue you stock struts to blow in a short period of time. But maybe some other people have had bad experiences, but from my experience it's rare. I've blown more shocks with Tockicos, Koni's and KYB's with race springs than I have with stock shocks and a prokit.
Zonian22
Nov 14, 2015 01:20 PM
Zonian22
Sep 2, 2015 08:19 AM
