power window
Old Jan 17, 2008 | 04:44 PM
rice_plz's Avatar
Car is Back
power window
Last night when I was going through the drive through i was rolling down my window and i would hear this scrapping noise like the rubber on the outside of the window was scrapping against the window. After i got my food i parked and could see that the rubber was down in the window slot. I tried to pull the rubber up then rolled down the window again but i could still hear the noise. Does any one know the reason why this might be happening? the window motor? maybe lube? thanks
Old Jan 17, 2008 | 06:55 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
On the outside or the inside of the window?
Old Jan 18, 2008 | 01:21 AM
rice_plz's Avatar
Car is Back
Old Jan 18, 2008 | 08:09 AM
STL+3.0CL's Avatar
Matt
Most likely your window mounts are a little loose which will cause your window to shift. That or its simply the window got stuck up on the sleeve/track and pulled that rubber down with it. If you roll it all the way down are you able to pry the rubber back up or did it tear off?
Old Jan 18, 2008 | 12:37 PM
Shoshinsha_KiDs_CL's Avatar
sold!
use pyroil!! it works
Old Jan 18, 2008 | 04:21 PM
rice_plz's Avatar
Car is Back
i put it back up but it was still making the noise but now it seems okay not making noise kinda odd
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
