polyurethane bushings
speed freak
has anybody ever looked into polyurethane bushing kits for our cars?...i read up on a lot of the sites but not quite sure what goes where and what i need to get to change the bushings and everything that i can....and if anyone has them...can u feel the difference?...
Swaps? $3000 for 50HP? :(
Let me know who you've looked at. No one that I know makes engine/tranny mounts out of urethane. Its all suspension.
Maybe the ones you've researched have the mounts I need.
I had them installed about 3 or 4 months ago and the ride was much improved. There're from Energy Suspension which I ordered from "MOBILEWESTONLINE.COM" I believe the person name was ross also known on this board as "rmstoico"
Yes everything, upper and lower control arm bushings, strut bar, balljoint & tie rod end boots, anti-sway bar & end links, etc... It has all bushings. This takes some time to remove the old and install the new, about 4 to 5 hours at least. Go for it, its worth it...
Midnight Marauder
they have all the poly bushings for the suspension and they also have the poly motor mount inserts for about $16 at summit racing.
I was looking at getting those added on to an order I was placing but then i remembered that i have a stock 2.2 engine.... not enough real power to make much of a difference... yet.
