Po401
Registered
Po401
I think that was the code that my car gave today. the guy from autozone told me i had to clean my egr valve. has anyone done this? the way he explained it to me, it seems pretty easy. thinking of attempting it this weekend.
ENGAGE MY VTEC BABY!!!!!!
it could be a 41 - Wheel Sensor Rt Front but i doubt it unless you got in a accident recently
there is no 401 its only 1's or 10's digits thats it here is a reference
http://home.insightbb.com/~niedejb/refs2.html
do the code pull yourself, use a paperclip and jumper the wires and pull the code yourself, if its a abs light then look at the abs codes, if it is a check engine light then look at the obdII codes
hope i could help
Joe
hope i could help
Joe
Registered
well a little while ago i cleaned the egr valve. it was really dirty, i put it back on but i still have the check engine light come on.
i think i am going to try pulling the code myself.
btw, thanks for the help 97acura
Registered
ok just tried to pull the code myself and i put the paperclip from the green wire to the red, turned the key and the check engine light just blinked once short. if thats correct, then the code is - Primary Oxygen Sensor Low/High Voltage
