painted the valve cover (pics)
before
after
I know the picture is kind of shitty but its because i used my phone, once my digital camera charges i will have better after pictures, i sanded for 4 hours and it came out much much better than it looked before i also replaced the gasket when i did it, and i accidentally ordered two off of ebAY so if anyone needs one ill give it to you for like 10$ shipped or something... but ya, gloss black to match the outside of the whip... let me know what you think.
after
yup, did that myself, fisrt i took the valve cover and the heat shield off, then i used a sharp putty knife and scraped all i could off, then i found some old paint stripper down in my basement and used that, then i sanded it with a fine grit paper, washed it with a brillo pad and some water... let it dry really good, did three coats of 500 degree paint primer, and then 3 coats of gloss black. spread each coat of paint out about 15 to 20 minutes apart, and then let it dry for 5 hours. i used Duplicolor Engine Enamel With Ceramic high heat(500 degree) paint, got it from auto zone for like 5 bucks a can...
so you went with the 500 degree on the exhaust manifold? i painted my buddy's preludes valve cover and EM, and it looks SWEET! i'll post some pics soon, but the 500 degree wasn't enough for the exhaust manifold. it burned up quick. so we redid it, not sure which degree we went with next. hope it goes well for you though. Ohh and try painting the letters on the valve color a second color. it'll look 100x's better.
Alright... I got it painted... it looks sick.. and whoever it was that said paint the letters a different color, i konw... I'm gonna go with a black over top it... and its red... I'll post pics tomorow maybe... or later today... its drying right now... hopefully it comes out good
def post pics!
Well I don't have the black letters on yet i needed to put it back on to go to my friends house but here you go, oh and I know the rest of its dirty, especially the battery and including the heat shield, i need some high temp gray for that... so yeah
oh and i ended up throwing on a new gasket
Originally Posted by spencer_homer
^ yea i questioned that, and the blue rubber bolt things on the valve cover. paint the bar red, it will look better
What crack were you smokin when you painted your stock strut bar baby blue? Did a clown help you?
Originally Posted by 5-speed
nice james
p.s.- did you get hit by a tornado today?
yea, the baby blue is a no-no unless ur color matching and its clear ur not doin that... def. paint the strut red, n the vc bolts black... n once u get those letters painted black it'll look sick
im thinkin out goin black w/ red letters
sorry guys i should of put this on my last post on this topic but... its alot easier if you put vasaline over the letters and area that your going to paint the second color, or just tape it off. i used vasaline, it was very effective and quick. hope this helps... nice red thats what we did on the prelude, with a silver color for the letters.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Also, pwner, you need to go to walmart or pep boys and get some battery cleaner, and get rid of all that nasty corrosion or get a new batt, it's killin your engine paint, shiz is nasty
With the vaseline trick do you hand paint or spray? I'm trying to find an easy way to spray my lettering on my 3.0 plate.
