our ABS orange light = Break problems
Fawkin Gruvin
On monday my red e-break light and the orange ABS break light came on has any one ever had this happen to them?? Then last night , my breaks gave out , at first the peddle was starting to be spongy and this morning my breaks are gone, it is lost fluid and i think that a line must have broken or some how i lost all of my fluid ?? but has any one ever had this happen to them ?? when i start the car the lights come on with the intail start up and then the ABS light goes off but in about a minute the light comes back on and stays on ? but the e- break light stays on and it is not engaged?? i hope it is not too much $ glad that i got those brembo cross drilled and sloted to put on yet!
i like orange juice
your abs light only controls your antilock.....doesnt mean your whole system is screwed...just means that they will lock up on you instead of pulsing........as for the other problems...that can cause your abs to malfunction but otherwise look for a line thats cut or broken....check you ebrake light sensor under the actual ebrake..it might be unpluged or not aligned w/ your handle.....
but to me it sounds like your m/cylinder isnt producing the pressure..if you have no leaks...then that could be your cause
ENGAGE MY VTEC BABY!!!!!!
i have this problem but mine comes on ever so often adn only comes on after driving about half and hour or so
i dont know whats up
anyone have any idea??? it only came on after my accident and i was thinking maybe i had a faulty wheel sensor maybe cause i know befoe it would come on if i went too fast like over 120 it would come on cause i have low pros and they would spin faster cuasing the car to think the cars going faster than it is
i dont know
anyone?????
i dont know
anyone?????
its paid for
When one of my calipers was leaking fluid i would get the red warning light for low fluid then when it got low enough the ABS would also light up. I just assumed that that was due to not enough fluid pressure in the system so the computer turned the ABS off.
I could not really see this leak because it was kinda slow and because of where it was at.
I had this happen on my acura. I had a break leak on the rear caliper. I was filling up the master cylinder with break fluid when it ran out. I took it over to the shop and had the brakes replaced and the rear calipers. Cost me about $1300 for the whole job. Fix it now, or your master cylinder could need to be replaced if you let it go to long. Sounds like you have a bigger leak than I did. My brakes felt more soft, but it took a while for mine to go out. Just know that is something that you don't want to wait on. Brakes you don't mess around with....my
Fawkin Gruvin
thanks guys i found it - there was a leek on the front passenger rubber break line. should i replace both sides at the same time?? i will do it my self on sunday, i still have one good front break.
it shouldnt be to hard. i love to do stuff my self , saving me $$ i love it !! how much would it cost if i had a shop replace one break line on our car??
since u have to bleed the whole system anywayz i WOULD replace the other one. someone could have let the caliper hang by the hose before during a brake job and messed up the passenger one, so they could have done it to the drivers one. eather way its only like a 10 min job, and like i said u gotta bleed all the brakes anywayz. so......
1 Post
you hsoulda just gotten stainless steel brake lines while you were at it. They would have lasted longer and imporved the feel of your braking. of course the only ones I can find are like $170 + shipping for all 4 all around.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
I had this problem twice, both times, one of my rear calipers burst, and I lost my entire brake system and pressure. Glad to hear that you found the bad line, loosing your brakes is scary shit. Good luck with the brembos BTW
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
HeloDown
09-08-2015 06:51 PM
