Obdii?????????
Old Jan 2, 2002 | 05:27 PM
clxtreme's Avatar
No Too Fast, No Too Slow.
Obdii?????????
what is OBDII? and Why would I want it on/off?
Old Jan 2, 2002 | 07:45 PM
RidinLow's Avatar
Scooby Guru
http://www.obdii.com
What you're referring to is the ECU reset, not OBD2. You can't turn OBD2 off without making your car very unhappy (unless you replace the entire ECU!). The ECU reset forces your car to "learn" what its got at the moment... breathing from an intake, extra spark from new plugs, etc.
Old Jan 2, 2002 | 08:58 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
ODBI used oxygen sensors to modify fuel injection.
ODBII does the same thing except it "learns" that your engine is changing (like adding more air with a CAI) and corrects for it.
ODBI would see the extra air and just add more fuel.
ODBII can tell that you have more air than normal and can tell the ecu that even though the throttle position sensor is at 100% open only use 80% in your fuel calculation now that he/she has a CAI.
Most of the learning has to occur on one or more trips before it is used. This learning includes coolant temperature, ignition timing, throttle positioning, O2 sensors, manifold pressure, etc.
Its nice knowing that the mods you do dont "disappear" after a week of driving.
Old Jan 3, 2002 | 06:39 AM
RidinLow's Avatar
Scooby Guru
OBD=On Board Diagnostics
ODB=Ol' Dirty Bastard
Old Jan 3, 2002 | 07:35 AM
niedejb's Avatar
You're not the first one to confirm I AM an idiot. Sorry
Old Jan 3, 2002 | 08:25 AM
RidinLow's Avatar
Scooby Guru
Hehe, just playin with you.
mada51589
Jan 9, 2025 04:40 PM
schen72
1G RDX (2007-2012)
Jul 25, 2011 03:05 AM
DJBOMBERMAN
1G CL Problems & Fixes
Mar 9, 2010 09:04 AM
jcooper97TL
1G TL (1996-1998)
Sep 15, 2008 04:22 PM
red00tl
Nov 13, 2007 02:47 AM
