Nothinbut problems help!
Old Feb 18, 2002 | 07:44 PM
PiMpIn2.2CL's Avatar
Well my car is STILL in the damn shop, i stopped there today and they said that i should get acamber kit for the rear, so ok.. i go to the shop order a Camber kit for my car.. but i am not sure if it will fit?.. Eibach.. 98-up accord 2/4door.. 4cyl.. will this fit? OO and is 195$ way to much for this or no?.. will it my my car handle better?...Thanx guys your the greatest
Old Feb 18, 2002 | 07:51 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Re: Nothinbut problems help!
I saw this on eBay today (there are 2 kits listed by this seller):
Camber kit
Otherwise, I don't know anything about them.
Old Feb 18, 2002 | 07:57 PM
dcsquirm88's Avatar
The camber kit that fits the CL's is the 94-97 accord. BTW $195 for a rear camber kit is crazy, that is way to much. I have the ingalls adjustable one on my rear and its only like $40-$60. Your car should handle better if your entire tire is getting traction as apposed to only the inside. Check out the ingalls web site for more info.
Old Feb 18, 2002 | 07:59 PM
So your tellin me the kit i got wont even fit?....
Old Feb 18, 2002 | 08:13 PM
dcsquirm88's Avatar
The camber kit that fits our cars is the 94-97 accord like all our other suspension parts (springs, shocks, etc...). Sorry man hope you can return it but it won't fit. You should return it any ways that is way to much money to pay for a rear camber kit. Either get one on ebay or check out ingalls at http://www.ingallseng.com/cars/acura.html
Depending on how low your drop is it will determine what degree of adjustment you need. Good luck
Old Feb 18, 2002 | 08:16 PM
dcsquirm88's Avatar
By the way the msrp prices at the ingalls web site are way off. I got the rear kit for under $60 brand new.
Old Feb 19, 2002 | 01:32 PM
Nugs3's Avatar
check size at tirerack.com
Old Feb 19, 2002 | 08:45 PM
So.. guys what camber kit should i get fora 2.5" drop ?
Old Feb 20, 2002 | 12:14 AM
dcsquirm88's Avatar
Whatever kit you get make sure it can atleast correct up 3.25 degrees of negative camber. Take care of the front first it has the worst camber problems after a drop. The front kits are more expensive than the rear aswell. I personally recomend ingalls its what I have on my car front and back and they are great. I had a progressive camber kit on my front before the ingalls and even though it stated that it could correct over 3.00 degrees it still wasn't able to correct my front camber. So watch out for false claims on the cheaper kits.
Old Feb 20, 2002 | 08:52 AM
moforose3.0's Avatar
What can I get ya?
Definatly go with ingalls, they are the best. Rmstoico has them for $85, thats the cheapest Ive seen.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
