noise when turning the wheel right
so yeah lately everytime i turn my steering wheel right theres this grinding noise coming from the front...i dont know if its the axel or stabilizer...the joints...have no idea...wha do u guys think...
if the noise comes when you are making a right hand of left hand trun then it is you drive shaft joints that need to be replaced...but if you hear the nouise while stationary then it might be your rack and pinion...am dealing with the same issue right now have already purchased a reman rack and pinion assembly and got both the drive shafts replaced as well some time back.......
for the drive shaft it is a constanat squeeking/grinding noise.....but for the rack&pinion it is a grding noise only when the wheels are truned to the extreme left or right even when stationary.....
my 2%
JFk
my 2%
JFk
no this happened to me wheel bearing is shot to hell on the side that the noise is coming from. good luck DIY'ing this one the shop i took it to had to use an acetylene torch to unfreeze it for removal
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Jan 25, 2016 06:00 PM
Mauricio.
