Windshield Wiper Not Working
Old Sep 22, 2008 | 04:50 PM
cw_ek9's Avatar
5th Gear
Hi everyone. My friend has a 2005 Acura CL and the windshield wipers arent working. Its weird cause the intermediate works but the other speeds doesnt... Does anyone have any suggestions? Thanks..
Old Sep 22, 2008 | 04:51 PM
SupraManAG's Avatar
One custom CL
My fathers Chevy Express Van has the same problem. I believe its the relay thats frupped up.
Old Sep 22, 2008 | 04:58 PM
cw_ek9's Avatar
5th Gear
Do u know what exactly I need to ask for? or part #? How much am i looking at to get it replaced... thanks!
Old Sep 22, 2008 | 05:08 PM
bRunCL's Avatar
There is no such thing as a 2005 Acura CL. If its a TL then it might be worth a shot to ask it in the TL forums.
Old Sep 22, 2008 | 05:12 PM
cw_ek9's Avatar
5th Gear
sorry i googled acura cl and it came up with this pic that says 2005. so.. i dont know what year.. but its this one:
http://www.autoleasebreakers.com/ima...mg/model1.jpeg
Old Sep 22, 2008 | 05:13 PM
MoSp33d's Avatar
N00berator
damn i was gona say...2005 CL...thrid gen of CLz hhahah sweet...but no its most likely a TL...if its a 4 door then yes a TL...u should give them a shot...but if it was me i would say its probably a fuse bust.
Old Sep 22, 2008 | 05:14 PM
white2.2cl's Avatar
ok thats a first gen 97-99 cl
Old Sep 22, 2008 | 05:16 PM
Blind_Shooter's Avatar
For Life
definetly a 1st gen acura cl from 97-99
make sure all of the fuses are good under the hood and under the steering wheel. if you do believe its the relay then i have a spare one if you need to buy it. they usually run around 50-100 depending where u pick it up at. i also believe the 94-96 preludes have the same relay assembly only slightly different looking.
Old Sep 22, 2008 | 05:18 PM
MoSp33d's Avatar
N00berator
hmm very nice CL...yup def. 97-99..It could be a faulty switch or possibly a defective wiper motor. What happens is moisture works its way into the wiper module which is mounted to the motor and eventually will short out both parts. or its just a fuse bust
Old Sep 22, 2008 | 05:20 PM
cw_ek9's Avatar
5th Gear
it cant be a fuse bust if the intermediate is still working right?
Old Sep 22, 2008 | 05:26 PM
white2.2cl's Avatar
maybe the wiper switch is busted cause if your getting power and its working on low setting my guess is the switch
Old Sep 22, 2008 | 07:03 PM
cw_ek9's Avatar
5th Gear
so its either the switch, the relay, the motor or the fuse.. dang.. i dont know which one to tackle first...
Old Sep 23, 2008 | 07:27 AM
swiftt5389's Avatar
probly the fuse. it would be the cheapest to fix no?
Old Sep 23, 2008 | 07:46 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Sounds like a fuse or the motor
Old Sep 23, 2008 | 04:13 PM
iansanderson's Avatar
'99 2.3 CL
do the wipers start on their own or when you swtich on the dome light? if so, could be a ground issue. I am not guessing the wiper motor is bad if it works normally on INT. The interior control module above the fuse box controls wiper functions but those rarely go bad. I believe there is a relay somewhere under the dash. I will have to check my service manual when I get home.
csmeance
Jan 7, 2026 06:25 PM
TL-Rocket
Apr 29, 2023 02:33 AM
oyayjoe
Jan 1, 2019 10:17 PM
acurajj
Sep 19, 2015 03:47 PM
08 NBP TL
Sep 8, 2015 08:49 PM
