Noise with A/C on
Old Aug 26, 2005 | 11:14 PM
infamouz trunkz's Avatar
Noise with A/C on
when im at a stop light with the ac on if i turn the steering wheel it makes this vibrating noise....how the hell i get rid of it and is it normal?
Old Aug 27, 2005 | 01:16 AM
wilp99's Avatar
what are the rpms at. prolly pretty low, and when u turn they go even lower. so the ps pump is struggling
Old Aug 27, 2005 | 08:43 PM
does that mean i have to get a new one???
Old Aug 27, 2005 | 09:35 PM
ajtcl's Avatar
Peace, Love & Acura
Check your fluid levels first. If it is the power steering pump, you will here a grindy-whining sound. If it is related to the a/c clutch, you will be able to tell by opening the hood and listening to the belt train. You might here a clattering sound while the a/c compressor is engaged. That is somewhat normal for an aging a/c clutch. In either case, you can probably locate the source of the problem by listening to your engine. You can rev it a little with the throttle control on the side of the throttle body. Listen closely with a probe if you have one.
Good luck.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
