New CL owner, Window problem...
Old Sep 13, 2004 | 06:25 PM
trip221's Avatar
8th Gear
Hey guys-
I just bought a '97 2.2CL last week, and no sooner than I get the plates switched over, the driver side power window quit working.
I took the door apart, and the cable that is attached to the power unit has somehow disconnected (broken piece somewhere?). As you know, it's not too easy to see around to the inside of the door. I bought the Chilton manual, and it does not help at all.
Is there an easy way to reconnect those cables to get the window working again? The window motor is making a couple funny noises, so maybe I should replace all of it at the same time. And I'm fairly mechanically inclined, so should I do it myself or take it to a shop?
Please give all your thoughts/suggestions.
Old Sep 13, 2004 | 06:28 PM
klepto's Avatar
our cars are very notorious for crap ass window regulators. A new one will run you $250 too
Old Sep 14, 2004 | 12:07 AM
CLver's Avatar
You can order a new one from HAP in Rancho Cordova for 85 new. shipping will probably be 12 dollars. That is where i bought mine when my window went out.
Old Sep 14, 2004 | 06:34 AM
wilp99's Avatar
or u can go to acura and get one for 145$ it only takes like 20 min to install. and chiltons suck. get the acura service manual here.
http://www.helminc.com/helm/homepage...HGC76V5RAL7NG0
thier kind of high but tell u anything u need to know bout ur acura from head to toe, and with good detail.
Old Sep 14, 2004 | 07:25 AM
vansonrider's Avatar
KLepto is right. Do it yourself and save the money and time. If you take it to the dealer you will be without your car for a day at least and out $250 - $350.
Old Sep 14, 2004 | 01:14 PM
klepto's Avatar
how hard is it to install what exactly is involved? I just spent a good 3 min in the parking lot trying to roll up my damn window
Old Sep 14, 2004 | 03:23 PM
ib_jimmy's Avatar
its not very hard....have the window almost half way down where u can see the bolts throw all the hoes. it will help if u have another person to hold it in place for u. should only take about 30min max.
Old Sep 15, 2004 | 12:33 AM
trip221's Avatar
8th Gear
Is the regulator the entire motor/cable/window attachment piece? Because the motor does work still, but the cable ends are not attached to the bracket attached to the window. I'm worried that if I buy the motor, I still won't be able to attach the cable.
Old Sep 15, 2004 | 09:39 AM
wilp99's Avatar
its all 1 piece. the reel drum is broken inside the motor. but yea if u order the motor the regulator and cables are all attatched.
Old Sep 16, 2004 | 08:53 AM
b16-to-j30a1's Avatar
hey man, you can get them on ebay for about $60 bucks (all one piece)... Just look under 94-97 accord, it you cant find any under CL. Make sure it is 2 door though... Just replaced mine a month ago. The hardest part is getting the door panel back on, so its a pretty easy job. Good luck.
Old Sep 16, 2004 | 09:01 AM
trip221's Avatar
8th Gear
Thanks for all the help guys. I can handle the door panel part, so I should be able to do this.
But one more question: Do I have to remove the window? Because it looks like a pain to put the bolts on that bracket that slides up and down the center channel, and to bolt the motor in there. Maybe there's a hole in the panel, I don't have it off right now, so I can't check.
Old Sep 17, 2004 | 06:49 AM
You dont have to remove the window. Start with you window almost all the way down. Take out speaker. Take out two bolts that go into plastic that window slides up and down on. Then push the window all the way up and out of the way. I used a piece of masking tape to make sure it stayed up. Then two top bolts, and two bottom bolts are all that holds the actuator in, remove those and the three that hold motor, and your out.
Old Sep 23, 2004 | 11:27 PM
trip221's Avatar
8th Gear
Just wanted to thank you guys for your help. Got the regulator today, and once I found the right socket, it took hardly any time at all. Let's just hope the other side doesn't quit working now.
08KBP_VA
Oct 22, 2019 01:55 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
Jimmy_D
Oct 7, 2015 11:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
jmaxima03
Sep 27, 2015 10:22 AM
