Need help within next hour... PLEASE READ
Old Oct 16, 2005 | 07:56 PM
blackacura's Avatar
I am having problems with my alarm, its being spontanious... when i first got the cl it did this for a week or so and the damn thing went off one day while i was in school they called me out there... not sure if it has to do with the cold weather or what, but the fucking thing is doing it again... the only thing i played with is the ground for the horn, i just cleaned it because the horrn/stop light fuse keeps popping, i noticed there are two wires that go into that ground slot, is this also the hood sensor? is there a hood sensor on factory alarm? If this is it can i just unplug the two wires that have the horn ground too, seing as i cant get the fuse to stop popping anyway? ANY HELP WOULD BE GRAETLY APPRECIATED...
Old Oct 16, 2005 | 08:03 PM
dragon084's Avatar
1999 CL3.0
disconnect battery, take it to where u baught it from tomrrow
blackacura's Avatar
bought it a year ago from a private party...
Old Oct 16, 2005 | 08:34 PM
blackacura's Avatar
hope this isnt going off all night keeping the neighbors up
Old Oct 16, 2005 | 08:40 PM
AS3.0CL's Avatar
F1 cart racer
disconnect the battery and just lock the doors normally until u can figure it out in the AM and get more help then
blackacura's Avatar
got class tomorrow morning...
Old Oct 16, 2005 | 08:43 PM
AS3.0CL's Avatar
F1 cart racer
disconnect the battery and lock the doors normally, this should stop it going off until tomorrow morning where u can figure it out and get more help by then.
Old Oct 16, 2005 | 08:48 PM
Lunchbox's Avatar
Scissor Me Timbers!!
Is it the factory alarm? The factory alarm system is a passive system. It should only go off when the door is unlocked or opened. It doesn't have a hood pin. If it's an aftermarket alarm it could be a host of things. That fuse that is popping sounds like something is making the fuse ground out or too many volts are being pumped through it. Take it to the dealer if its a factory alarm.
Old Oct 16, 2005 | 08:57 PM
teh CL's Avatar
make sure your hood is closed
Old Oct 16, 2005 | 09:05 PM
wilp99's Avatar
i think you can adjust your hood sensor up to make it compress all the way.. it might just be partially compressing. that or replace it.. alot of people have had problems with it.
Old Oct 16, 2005 | 09:11 PM
teh CL's Avatar
i did
Old Oct 17, 2005 | 01:33 AM
ghost_masterCL's Avatar
I had a problem with the hood portion of the alarm, but only after I got backed into by some old man, I just unplugged it. :/
Old Oct 17, 2005 | 01:43 AM
Andrewmc621's Avatar
i had the same problem.....your alarm is just most likely sensing that the hood is open....there is a green wire that runs from under the passanger seat to the front of the car, just unplug it from either under the seat or up front by the hood. the alarm will still work, just if someone opens the hood the alarm wont go off now
Old Oct 17, 2005 | 06:31 AM
ayougo's Avatar
B A N N E D
good to here
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jimmy_D
Oct 7, 2015 11:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
