Need help.....guyz
Old Dec 14, 2004 | 07:32 PM
cl-baller201's Avatar
2.2CL owner
Need help.....guyz
My back rear passenger side brake.....is locked. When i try to drive the car, the brake is preventing me from going anywhere. I mean i can drive but the brake is engaged.
Its like the emergency brake is stuck on that side or something, plus the last time I drove my car my rotor was bright red..........What you guys think is the problem.
can i just unlock it myself.........I am prbly gonna take it to mineke or someplace.
what ya'll think?
plus the ABS light came on.
Old Dec 14, 2004 | 08:11 PM
CL2.3-Amature's Avatar
Look out ladies
Possibly a seazed brake caliper? If this is the case you will need a new brake caliper.
Old Dec 14, 2004 | 08:40 PM
proaudio22's Avatar
-S namyaC-
Bright red rotor? DUDE - you are risking catching some shit on fire. Your pads are probably disentagrated by now too unless you have some fancy racepads (which you prob don't).
Sounds like the E brake is stuck or the caliper is seized. Open the center console, pull out the bottom tray. Look at the two e-brake cables and move the handle up and down and watch them.
Old Dec 14, 2004 | 09:16 PM
2.2CL owner
holly shit dog
U got me with this one
dam U think I can take it to minekee.....cuz I got no clue.
I thought it would release itself.....cuz this happen one time before. And it did release itself.
Old Dec 14, 2004 | 10:11 PM
proaudio22's Avatar
-S namyaC-
It prob has something to do with the fact that the rear caliper uses a "screw" design to facilitate the emergency/parking brake feature.
Standard calipers work by pushing outward towards the pads (duh lol). On the rear calipers on the CL, they actually come out in a rotating fashion, as if you were using a screwdriver to twist it out. The cables from the handle in the car twist the calipers out creating the same pressure the fluid does. It sounds like the caliper is stuck out and you are driving around with the pads locked on the rotor, and they are burning up. You should be able to take it to any reputabe brake shop. You'll prob need a new caliper on that side, plus new rotors and pads on both sides. Prob ought to change the calipers on both sides while you are at it. They also might be able to get your caliper unstuck with some lube, but who knows if it might happen again (rust? salt corrosion? old? all of these?).
Old Dec 15, 2004 | 11:23 AM
2.2CL owner
yea iam gonna take it to my local mineke........cuz its down the block from where my car is parked at. And I would rather not drive it far.
its prbly gonna be what you just said.........plus i got a flat on that same side
I gotta take care of this problem.
Old Dec 16, 2004 | 02:07 AM
wilp99's Avatar
im pretty sure the caliper is toast. if ur brakes are worn enough ur caliper could come completly out of the sleeve and get stuck out. ur gonna need a new rotor and pads also. be careful with brake places cause they love to charge alot of money for a cheap job. before u go just remove the wheel and smack the side of the caliper with a hammer. this may break away the e-brake if its stuck on.
Old Dec 16, 2004 | 11:19 AM
2.2CL owner
Yea Iam gonna C if i can get it loose,
