Need help getting stock stereo to work!
teh Senior Instigator
I just installed the stock deck I bought from SooDark a few months back because my CD player stopped reading CD's. Well the only difference between ours is his says bose on it and mine doesnt but I was told that doesn't matter. Well the new deck will take teh CD but doesn't have any sound, the radio works fine. Aren't there only 2 connections, one for the antenna and one that plugs into the deck? What am I doing wrong?
Proaudio? any of you hoppers?
it's not aftermarket, i'm trying to reinstall another stock head unit, however it's from a 2.3 not a 3.0. The only difference is that one says bose. I was told both units are the same except for just the lettering. I guess it appears this isn't true
proaudio thought they were identical. If they weren't compatable I would of figured the radio wouldn't work either
Originally posted by dustbuster4
Does the headunit look like this in the rear?
Come to think of it, I think the harnesses are universal on 1990-1997 Honda products.
Yes, the 1990-97 harnesses are the same for most of the hondas and acuras (with the exception of the Passport-- the Isuzu SUV). The non-bose stock unit will not work with the cars originally equipted with the bose units (if you plugged it in directly to the car's harness). That non-bose unit is "like" an aftermarket unit...it has an internal amp...that can pass signals directly to a speaker.
My car is a 99, so was his. on 99's all cars had the bose systems I believe
I may just say fuck it and throw in an aftermarket deck. What do I need to do that?
Scott,
I know that all '99 CL's were Premiums, but only the 3.0 got the Bose System. The '99 2.3CL Premium got the "regular" headunit.
For an aftermarket unit, just hardwire the aftermarket harness to the stock wires, and bypass the stock amp (or run all new wires to your speakers/power source/ground/aftermarket amp [if you have one], etc.).
The diagram I posted above should help you with hardwiring the aftermarket headunit's harness.
Just buy a new hu and call it a day..no more headaches...LOL...u could get a decent one for 300 or even lower if u just want a reg one. Don't ask me though cause i'll tell u to buy a high end one..LOL.....
i'd like to spend 20$ on a stock one
you still got yours around? I'll give you my broke one for when you go to get rid of it, it still plays radio
try not connecting the bose amp. perhaps the amp is confusing stuff.
and if you have a BEST BUY somewhere nearby, tey're running an ad right now saying free install on CD decks 99 bucks and up.
Originally posted by baka_t
Maybe your car dont have a bose system?? Check in the trunk on the pass side behind the tail light for the amp. Since his said bose and your's didn't.
mine said bose, his doesn't
Did I read the first post correctly? There is no audio on a CD but the radio does work fine (IE you can hear it?). If you have audio playing from the speakers with the radio, something inside the player is messed up. It's either all or nothing.
I dunno bro, I was pretty sure they were the same thing. All the Bose amp does is add their supid ass EQ and reamp the signal to be compatable with their $.99 2ohm speakers. The Bose amp will take an amped signal from another source (IE aftermarket radio) so stock should just be the standard radio. I can test mine for you if you need to be sure audio will play, but I gather you do have some audio from the radio...
no problem at all bro, not your fault in the least bit. I didn't ask you they were the same till AFTER I had bought it
sockr1
10-01-2015 01:31 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
Gianni Formica
09-07-2015 08:28 PM
yahelou
09-06-2015 09:12 PM
