Need help with the "Brake Warning" light
First I would like to say that I did check the fluid level and the pads etc are all new.
The light comes on perodically while driving and when the car is cold no big to me, but the problem is that when the brakes are pressed only the drivers side one works. The passenger side and the center one in the back window do not work. I know it's not the bulbs 'cause when I turn the lights on they all work?
Any ideas what this could be? I need some help here THANKS GUYS
Hook 'Em Horns
Hook 'Em Horns
Two pieces of advice, I had a similar problem, only I would always blow my brake light bulbs every couple days. Clean out the bulb sockets, my problem had to do with water being inside the socket (no idea how)
Other suggestion, check fuses, if the passenger side fuse might be blown, they may be linked together, your middle fuse and pass side
Originally Posted by spencerlonghorn
Thanks for the help I will try this and let all know how this works
THANKS AGAIN
THANKS AGAIN
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Ny1718
Sep 11, 2015 09:21 AM
