Need help asap, car turns over but wont start
Hey guys. My car is being a complete asshole lately. I was driving and the thing shut off on me, I'm pretty sure it overheated but I couldn't tell because my temp gauge is broken. Tried to turn it on, the car turns over but wont start. So I thought maybe it was the spark plugs and/or wires, so we tried to take them out and replace them, the plugs were melted on so we finally pried them out and gt new wires and plugs. The car still turns over but doesnt start so I'm at a loss for what the issue is, someone plz help me. I just want to get the car running and sell the god damn thing.
I just ran a diagnostic on it and it said system too lean and engine coolant temperature circuit low so idk why the system would be running lean
yea, my coolant is very low but I didnt think that would affect if the car started, only when its going it wouldnt properly cool the system and would eventually overheat. Also with the thermo, I figured the car would start and again, overheat. But I will definitely try those guys, thx
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Uh yeah, coolant is VERY important for starting your engine and it being able to run solid, I hope you didn't burn up your engine since the spark wires were melted def put some coolant in that shiz
B A N N E D
Sounds like your car got hot as hell, and now you can't start it. Good thing your car knew when to call it quits...You couldn't smell it getting really hot or anything?
I went to the track once, and it didnt smoke or anything, I just assumed it overheated because a little bit of water had dropped out of it and a little steam came off where the water hit the timing belt, also the wires had melted. My hg isnt blown, but the diagnostic said the system was running too lean and I can't figure out why it would be running lean all of a sudden.
edit-I think I want to try and flush my radiator, how would I go about doing it? And I have a new thermostat to put in, where is that located?
(Mid-Atlantic)
(Mid-Atlantic)
You can't flush a rad without a rad flush machine
You can drain and fill though, just like every other fluid on a honda.
There's a twistable plastic drain plug on the bottom of the rad, you will have to remove the plastic shield underneath to get to it, just open the bleed/drain plug WHILE THE COOLANT AND ENGINE ARE COLD! and just drain all your coolant out make sure if you have pets ie: dogs or cats that you clean up any spills extremely well or they will lick them up, once all is drained, replace drain plug and fill with 50/50 mixture, prestone 50/50 will work just fine, there's only 2 companies in the world that actually produce antifreeze, it's just branded differently.
Once full, run the engine with the fill cap OFF and let it bubble down until it's full, top off as neccessary and make sure there is at least something in the overflow bottle.
The thermostat, there are pics and diy's posted on here, search
you can buy a "flush" fluid, and it actually cleans out some crap. When you refill, (make sure the car is off) put coolant to the top, and put your hand over the refill hole. Then squeeze the top hose that feeds into the engine a few times. This creates a slight vacuum pressure, and helps push the air out of the coolant lines and radiator. Then fill to the top, and repeat until fulll. Just a little trick I use.
i think the thermostate is inside the engine where the top radiator hoses connected to. take off the hose and it should be there.
migh be wrong, correct me if am wrong.. am going to change my radiator and thermostat this weekend. the pos is leaking coolant everywhere.
Nom Nom Nom Nom
Be sure to replace the gasket with a new one.
Originally Posted by SwervinCL
For the most part.. Its on the upper rad. hose. Follow it to the block, you will see the housing with 2 bolts. Take off the two bolts and the thermo is right there.
wow... we was wrong... -.-'' f23 the thermostat is at the bottom hose... how i know? i change my radiator today and i bought the thermostat to change that too but while i take apart the old radiator and took off the top hose from the engine found out there wasnt a thermostat there -.-'' so i just hook up my new radiator and bring back to autozone the thermostat. am to lazy to change it.. to much work hahahaha look like a mess.
correct me if am wrong.. i just know it not at the top.. and if it not at the top commen sence it is at the bottom hose... i use the search button but then got a headace from reading stuff that i dont need to be reading ehhe
...nO phOtOshOp...
check to c if ur ICM(igniter) is bad... its a little matchbook size module inside ur distributor... if u take it out be sure to draw a diagram of how the wires are connected... did ur tach ever drop down to 0 then jump back up....?
I have no idea lol, some water hit all the belts, maybe it got slippery and skipped? Dont really know and dont really care, just need to fix it.
(Mid-Atlantic)
(Mid-Atlantic)
that's some expensive shit
(Mid-Atlantic)
(Mid-Atlantic)
Hope your friend has a timing gun so you can set your timing, remember to start at top dead center
yea, I might pick one up, use it for the job and sell it if he doesnt have one lol
Yea, no turbo, I'm pretty pissed about it actually, the job I was banking on didnt pull through quick enough and I need money for next year so sellin the car and picking up a cheaper one, I'm gunna miss her tho...
one question... if you don't mind explain to me how u figure that it your timing belt when you are not sure what it is.. you said water must have been on all your belt and it got slippery.. i spray down my engine bay and nothing wrong with it.. i did this a few time. car has 151.xxx on it.
crap couldn't edit the top...
you dont have to answer if you dont want to but it be nice if somoene on the board have the same problem as you and need to know what is the problem, we could look at this page to follow up on it and fix the problem, as in helping other. figuring out how it is the timing belt... i meant.
thanks
thanks
NAWWWWSSSSSS
1 Post
...nO phOtOshOp...
Originally Posted by F23CL757
Check your fuel pump too, i had a problem like that with an old Altima I had.
im sure you kno this suprachica, but all have to do to check if your feul pump is bad is turn your key to the on position... you should hear a buzzing/whining sound for about 2 seconds (this is you fuel pump priming the system)
i think you said this wasnt the problem tho so i dunno
saberlove
03-11-2021 09:29 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
