Need Answers Asap!!!!!
ok so today my exhaust rusted out but thats no biggie. the bigger problem is that my tires all wear on the inside edge. now i know thats a camber problem and i had that fixed before winter happened and now i have the same problem again. is it because the frame might be bent or what could it be. this car has been from michigan to ohio to here and it was in a wreck and i hit a deer this fall so that might be it as well. i need to know asap i want this car problem fixed or resolved. thank you please help MEEEEEE
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
You're not lowered yet are you? Sounds like an alignment / camber adjustment problem, get it done on a 4 wheel computerized laser alignment machine. Otherwise the frame could be twisted, but sounds more like your alignment is out of whack
if you aren't lowered then your toe is off. more toe than camber. If you are lowered then its deff your camber. either ways you need a wheel alignment. before you do so, find out if the people you take it to do a good job. most people dont know how to do a wheel alignment because they are simply retarted. the first place i took it to overcharged me and did a real shitty job. everything came loose in a month. so beware.
im stock still yes...i had my camber and alignment done today which im lucky we know the guy who does ours...turns out nothing is wrong and its not my driving and he thinks it is a bent frame that is doing it.
needless to say it was a frame problem...insurance is going to give us money for it and im buying it back for 1500 so itll be mine again then off to get a beater and become one of project sneaky member
Eggs999bacon
09-24-2015 10:08 AM
Mugen TSX
Eastern Canada
09-16-2015 09:52 PM
Billu99tl
09-13-2015 11:30 AM
