My CL Won't Start!
Old Feb 22, 2003 | 08:10 PM
Iced_Teal_CL's Avatar
My CL Won't Start!
I was doing some work on my 1999 3.0 CL today. I removed a system that I had in there and some fog lights. I disconnected the battery to remove the foglights. I took a break for a couple hours and then when I hooked up the battery again, the car wouldn't start! What gives? The first couple of times when I tried to crank it, I just heard a "click." Now, I hear nothing! The interior lights come on, but when I try to start the car, nothing happens...the dash lights just barely come on.
Did I screw something up? What could have happened? I don't see how the battery just drained like that. Please help with any advice!
I plan on trying to jump start the car tomorrow, or getting Acura TLC to come by and start it up.
Old Feb 22, 2003 | 08:23 PM
RidinLow's Avatar
Scooby Guru
Make sure the terminals on the battery are clean and that there's a good connection. You can try one of those battery post cleaners with the wire bristles.
Old Feb 22, 2003 | 08:30 PM
blackacura54's Avatar
yeah try jump starting it
Old Feb 24, 2003 | 06:51 PM
superj721's Avatar
I'm rich biatch!
how old is the battery, maybe you have a dead cell.
Old Feb 25, 2003 | 02:25 PM
turbotk's Avatar
its either:
battery
altenator
fusable link
Check them all. start with the battery and then altenator
Old Feb 25, 2003 | 02:31 PM
Sacramento CL's Avatar
A-CL Member
It could be a broken battery cable, too. That just happened to my Rodeo. It acted like a dead battery and wouldn't start unless jumped. When I tried to charge the battery, it wouldn't draw any juice. Turned out my neg cable needed replacing.
Old Feb 25, 2003 | 03:06 PM
swclown's Avatar
4-8-15-16-23-42
i will almost guarentee your connections are not tight enough or there's corrosion on them. clean and re-tighten -if the lights come on it is a sign that there IS a connection but when you crank your engine there are too many amps to pull through the bad connection (surface area) so if you clean and tighten i think it will fix your prob (-:
Old Feb 25, 2003 | 04:58 PM
djz's Avatar
djz
Music for your Mind......
fuck it
your car is trashed.
you should take a can of gas, douse the interior, light it and RUN!
WHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
remember.......dont forget to run.
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
