My car will not start
Old Aug 28, 2004 | 03:04 PM
ju5tchi11in's Avatar
roomate has a CL too
the worst my car won't start was fine yesterday night
this morning it doesn't turn over the starter just clicks and clicks and clicks.
wondering what this could possibly be. I checked connections and fused and other stuff seem fine I was wondering if it is a fuel problem
this sucks.
Old Aug 28, 2004 | 03:12 PM
xrunner86x's Avatar
A-CL Totaled Member
I cant remember for sure, but i think clicking starter = low battery or dead starter. If it was a fuel problem the starter should still be able to crank it but it wouldnt start.
labmeister's Avatar
USTHS76
If the battery is still good, it's probably the starter.
Old Aug 28, 2004 | 03:14 PM
wilp99's Avatar
check the chassy ground. if it is too corroded the starter will act like a bitch.
Old Aug 28, 2004 | 03:15 PM
chuchuctrain's Avatar
WhatCanChuDoForMeToday?
do u have after market alarm system? if so, then sometimes u would have to unalarm again before u could start it.. happened to me on my stupid civic.
Old Aug 28, 2004 | 03:55 PM
CLpower's Avatar
teh Senior Instigator
sounds like the battery, maybe the alternator is shot
Old Aug 28, 2004 | 04:42 PM
lights come on and vents and radio... so battery is fine I am assuming. just no turn over of the engine just clicking I think the clicking is the starter right? no engine sounds other than clicking of the starter when I turn the key.
where is the chassy ground located? I'll need to check that.
fuck how did my started just die... something happened to my friends accord yesterday that had something to do with his starter.
Old Aug 28, 2004 | 04:43 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
its definately the starter silioniod, i had mine rebuild for like 50 bucks at a rebuild shop in Modesto
dont get a new one, have the old one rebuild, and you can save some money, the alt. if it was going out, it would start on you but then would die on you quick, since you are hearing the clicking sound, it is the starter siliniod trying to click over and start but it is fried and should be rebuilt, a new one is pricey about 100 bucks or so
rebuilt is basically brand new part just using the old casing, the shop that did mine even painted the new one a solid black color for some nice dress up look free of charge
try taking the starter off and taking it to a shop and have it tested
Old Aug 28, 2004 | 04:46 PM
MikeSwing's Avatar
It sounds like your starter. I got another one from Autozone with a lifetime warranty for $118 and put it in myself. Took me about 30 minutes. Really easy. Just disconnect the wires to the battery and remove the two bolts. I also got a Optima red top while I was at it.
Old Aug 28, 2004 | 06:23 PM
wilp99's Avatar
just because the radio works doesent mean the battery is good. u could take the starter off and have it tested at autozone for free, along with ur battery. but i would still check the grounds first.
Old Aug 28, 2004 | 06:34 PM
DanMan1464's Avatar
Autobot
check the spark plug main distributer. Make sure the main plug is plugged in all the way
Old Aug 28, 2004 | 06:52 PM
CLpower's Avatar
hopefully he's hammered right now and in front of a TV for kick off
Old Aug 28, 2004 | 08:31 PM
MJMeucci's Avatar
This just happened to me, all lights and stuff worked fine, but the car clicked when I turned the key... it was the battery. $80 later after a visit to sears it was starting strong once again.
Old Aug 29, 2004 | 03:53 AM
krazy99cl's Avatar
O.G.
starter man. u can get it also for an accord...it will fit...just check if it has the same thread, when you open it....it should work...mines was from a 1998 accord....i dont know if a v6 would work, but check.....
Old Aug 29, 2004 | 02:19 PM
about to take the starter off in a few minutes anyone on at the moment know where the grounds are that I have to check? I have a 2.3
CLpower: I was drinking a bit before the game... a good one. I was worried.
I'll check my battery at autozone good thing it is only 2 blocks away.
Old Aug 29, 2004 | 02:50 PM
sskillett's Avatar
I noticed you have a manual tranny CL. There is a switch at the clutch pedal that allows the motor to start when you depress the pedal. To test, when the car is just "clicking", put the car in nuetral, turn the key & move the clutch pedal in and out. It might just need adjusted. This happened on my manual tranny equipped Accord. It was very intermittant, just like what you are explaining.
sskillett
this sucks.
Old Aug 29, 2004 | 03:06 PM
sskillett
push the clutch pedal in and out while turning the key? or when the key is turned to ACC
I can't get the top 14mm bolt to budge...
I believe the bottom one to be a 16mm or 17mm? I can't tell I cant see it I'll probably have to raise the car up which is a problem since I can't drive it up a ramp since it doesn't start lol.
the worst.
just tried it.. I reread what you said while it is clicking... nothing.. oh well back to the drawing boards.
Old Aug 29, 2004 | 11:52 PM
ok so I took out the battery put it on my skate board and rolled down to auto zone to have it tested. Turns out the battery was bad so I bought an overpriced optima yellow... 159.99 plus tax... yeah I know that is fucking expensive but my car was dead so well I got it and put it in... started right up... the worst... fucking ac delco batteries.
anyway case closed thanks for all who helped.
Old Aug 29, 2004 | 11:58 PM
TypeSblkura's Avatar
JAPAN
jiggle your battery wireing a little and it should work...aftermarket electronic installers often do a crappy job of wireing...it worked for me so give it a try
Old Aug 30, 2004 | 06:19 PM
if you read the last post... you would know I had a bad battery and I replaced it with an over priced optima yellow battery...
thanks for your help but case closed.
:padlock:
Old Aug 30, 2004 | 07:08 PM
wilp99's Avatar
maybee if u skateboard the battery to autozone and find out its bad and buy an overpriced optima yellow ur car will start.
Old Aug 30, 2004 | 07:21 PM
ib_jimmy's Avatar
i'm thinking its ur starter bro, does ur car seem like it have power? headlights comes on? interior lights on bright?
Old Aug 30, 2004 | 07:33 PM
babyloc86's Avatar
ill answer that for u jusschilling. jimmy, it wuz his battery. his car is working now. he had to skateboard to autozone and bought overpriced yellow optima. :P
Old Aug 30, 2004 | 07:41 PM
damn all that work and its only the battery
the clicking i got was my starter
hrmm....... oh well as long as its fixed, good job Rob
Old Aug 31, 2004 | 05:00 AM
My sarcasm meter just hit the peg... lol... babyloc I think he was being sarcastic... haha.
Old Aug 31, 2004 | 08:00 AM
wilp99's Avatar
someone please lock this before i hit 1000 posts.
Old Aug 31, 2004 | 12:14 PM
babyloc86's Avatar
seriouse. :padlock: :P
Old Aug 31, 2004 | 04:39 PM
whats wrong with you guys... just stop posting in it and it will fall of page one and no one will give it a second look.
Old Aug 31, 2004 | 06:19 PM
babyloc86's Avatar
shut up u post whore! haha jK :P
Old Sep 1, 2004 | 12:18 AM
actually there is another problem now... my engine has a hard time turning over when I turn the key.... shit... so maybe my starter really is going... I'll have to check it out... but I couldn't get the bolts off last time I tried.
I don't want to kill this expensive battery too. I think Im going to buy some new sparks and some new wires. time to ebay it up.
Old Sep 1, 2004 | 04:54 AM
babyloc86's Avatar
ebay it up
btw rob. if u find good deal on spark plugs and wires, hit me up. i might get them too.
<---- 500 POST!!!!!
saberlove
Mar 11, 2021 09:29 AM
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
