Making your lude shifter shorter: JDM gettho style
After installing my prelude shifter, I noticed a big difference in height and feel but I still wanted something shorter. I got inspired by my brother who drilled out his shift knob on his E36. I used my JDM lude shift knob which is the same knob as the stock CL except this one is from Japan
and it's all used up and such. First thing I did was cut off the plastic clip for the boot using a reciprocating saw
I then drilled with a 1/2" bit about 2/3's of the way in the shifter and then I switched to a smaller bit. I used a bit just a tad smaller than the actual shifter thread diameter. I drilled up until I saw the bit pushing up on the leather. I installed it in the car and WOW what a difference 5 minutes can make... It shortened the shifter a little more than 3/4's of an inch. I also fabbed up a custom ring for the shift boot out of a rubber grommet I purchased at the hardware store... The next step is to do it to my RSX knob...
Stock CL shifter with RSX knob
![](http://i20.photobucket.com/albums/b246/318_ti/IMG_2612.jpg)
Prelude shifter with RSX knob
![](http://i20.photobucket.com/albums/b246/318_ti/IMG_2669.jpg)
Height difference between RSX and JDM lude knob (If I do the same process to the RSX knob, it should be even shorter since the knob is a little smaller)
![](http://i20.photobucket.com/albums/b246/318_ti/IMG_2672.jpg)
Rubber grommet mod (held in place with a tiny zip tie on the underside)
![](http://i20.photobucket.com/albums/b246/318_ti/IMG_2666.jpg)
Inside of the modified JDM knob
![](http://i20.photobucket.com/albums/b246/318_ti/IMG_2667.jpg)
Finished product...
Knob is ugly but you get the idea
![](http://i20.photobucket.com/albums/b246/318_ti/IMG_2664.jpg)
I could do a DIY if there is enough interest...
acuratl_2nr
Finished product...
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
acuratl_2nr
Originally Posted by ZeroCL
Leather mini skirt that didnt fit anymore or what?
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
![Spit](https://acurazine.com/forums/images/smilies/spit.gif)
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
suite
Iakonafuji
09-21-2015 02:39 PM
kixo
09-05-2015 08:54 PM
