maintence required
Old Apr 7, 2006 | 03:49 PM
JORTS's Avatar
maintence required
hey guys, the maintence required thing (under speedometer) turned red awhile back....
i just wanted to make sure that this was only there to remind you to change your oil...that was what it was for in my old acura vigor....but when i put the key in the place to reset it back to green nothing happens....i want to make sure its not trying to tell me something else is wrong...i dont have the manual to the car so i have nothing to reference this problem with
thanks
Old Apr 7, 2006 | 04:04 PM
ItsDave's Avatar
If you look in your manual it tells you the different reasons the light goes off once you hit a certain mileage. But I know that there are more things than just oil that are in the scheduled maintenance.
Old Apr 7, 2006 | 04:45 PM
Smalls's Avatar
Insert Sarcasm Here
Old Apr 7, 2006 | 05:24 PM
ghost_masterCL's Avatar
wow you guys are both idiots. he said he doesn't have a manual to look at. Maybe you shoudl learn how to read and stop beign jackasses.
@ JORTS: yes it's pretty much just for oil and scheduled maintenance and shit, nothing to worry about, as long as you do the timing belt/water pump stuff at about 100k and the other suggested maintenances like 30k and 60k.
Old Apr 7, 2006 | 05:53 PM
krazy99cl's Avatar
O.G.
i think so too.....if its a mechanical issue your check engine light will turn on....
Old Apr 7, 2006 | 05:54 PM
krazy99cl's Avatar
O.G.
how many miles on it when it turned red?
Old Apr 7, 2006 | 06:22 PM
732xghost's Avatar
and you know if you get an oil change and it still doesnt turn back to green, stick your key in that hole by your speedometer.
Old Apr 7, 2006 | 06:23 PM
CLsuperhero's Avatar
reset it using the buttons on gauge cluster or disconnect the battery. You'll be fine.
Old Apr 7, 2006 | 06:41 PM
LOL!!! he even said hte tried to use the key to reset it but it didn't work. people around here really need to work on their reading comprehension.
mine was red a little bit ago and to reset it you can just stick any key into that hole thing, but you kind of have to vary how hard you press it and how fast, just try a few times and it'll eventually reset to green.
Old Apr 7, 2006 | 07:27 PM
shnee's Avatar
Land of Pleasant Living
put your thing in the hole until it turns green
Old Apr 7, 2006 | 08:23 PM
teh CL's Avatar
and
Old Apr 8, 2006 | 12:44 AM
SupraManAG's Avatar
One custom CL
pay no mind to that maintenance indicator
its gay
you could go 10,000 miles and it will remain green
best way to do your oil is by writing down your mileage or timing yourself
Old Apr 8, 2006 | 12:51 AM
Shaggz2Dope's Avatar
2.2 auto and coping
it changes a 7500mi.....
and you should NOT change your oil based on that.....thats 2 oil changes right there...
its meant to make you go to the dealer and pay for things you dont need
Old Apr 8, 2006 | 01:54 AM
krazy99cl's Avatar
O.G.
hahahaha!.
ok
Yeah...stick your keys in
Old Apr 8, 2006 | 11:46 AM
JORTS's Avatar
thanks
thanks guys...
i am going to hit 89,000 miles today or tommarrow and when i last talk to the acura dealership that said that i should bring it in for the big 90,000 tune up...
1.what all does this cover from the dealership?
i am only assuming it will cost out the ass...
2. can i get this done at a cheaper shop or should i take it to the dealership?
3. anyone outthere have had this done through the dealership before?
4. does it make a huge difference? i bought the car with 79k and all i have done to the engine is change the oil and get a new clutch....so i guess i want to get this tune up done....
what do you guys think??
Biggie_B
May 27, 2025 05:51 PM
joflewbyu2
Aug 18, 2019 10:38 PM
urbtsx
Sep 27, 2015 09:40 AM
lowgrowl
Sep 26, 2015 05:18 PM
