WTH is wrong with my audio
Old Apr 7, 2006 | 08:33 PM
silvercl3.0's Avatar
i posted in A/V forum but got no responses and this crap is buggin me liek crazy. well i got a this cheap kenwood deck 50x4 that i installed. 6x9 sony Xplods, and stockers up front. no amp. well when i turn up the volume on the deck, it goes up to a certain point then it cuts off, it like turns off and dies. the point where it turns off is different for everysong, but the thing is, is that if i turn on my headlights i can turn up the volume a little bit higher before it cuts off.
anyone got any ideas why is does this? i already checked the grounds. bypassed the amp from the instructions i got on here.
Old Apr 8, 2006 | 12:47 AM
SupraManAG's Avatar
One custom CL
battery sucks balls
mine dies after i blast my bass for a while
check your alternator and battery
Old Apr 8, 2006 | 04:08 AM
wilp99's Avatar
use a better ground.. make sure your wiring is correct. are you using an adapter?
Old Apr 8, 2006 | 12:51 PM
a better ground where? i used an adapter that i got from Best Buy
Old Apr 8, 2006 | 01:43 PM
wilp99's Avatar
dont use the ground wire from the harness ground the radio using the black wire from the back of the radio to the frame.. also check your fuse size on the radio and the fuse box
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ValdezQ26
Oct 1, 2015 04:48 PM
navtool.com
Sep 25, 2015 05:15 PM
