Lights dimming after installing pulleys
Old Sep 2, 2002 | 09:32 AM
moforose3.0's Avatar
What can I get ya?
I was wondering if anyone was havin problems with their lights dimming after they installed their pulleys. When the car is sitting in park or at a stoplight and the rpm's are low the lights get dimmer and then as soon as I give it gas and the rpms go back up my lights go back to normal. Does this sound like an alternator problem possibly? I am running a decent amount of wattage to my amp, maybe I need a larger alternator???
Old Sep 3, 2002 | 01:40 AM
ilike2cheez's Avatar
i think i acutally notice that too. Its not that noticeable but i think its ok. It could be imagination. I donno. i ahve 600 watts RMS to my amps and my back speakers are ran off the radio so i guess we in the same boat.
Old Sep 3, 2002 | 07:16 AM
AdiKEEPER's Avatar
3rd Gear
This is happeneing because by installing pullys, you are making your alternator have to work more, because more power is being used for the motor, and less to help the alternator run. Be careful when using your stereo, because if you have a high power stereo, you could screw something up in the electrical system.
Old Sep 3, 2002 | 08:48 AM
FrstGenCL's Avatar
Exactly... you have to expect that when you install pullys... it comes with the teritory... the 600 watts RMS is definatly not helping the situation...I probably run less than 600 watts RMS between two amps and I have a stock alternator, stock battery, and NO pullys and my lights dim when my bass hits.. try to upgrade you alternator...
cycdaniel
Dec 17, 2019 10:58 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
PortlandRL
Sep 14, 2015 12:01 PM
Nicho863
Sep 2, 2015 08:12 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
