Leaks
Old Jan 1, 2003 | 04:26 PM
Ted's Avatar
Ted
Leaks
Today I was with my girlfriend today and stopped at my friend's store for a while. Unfortunately, she had been feeling sick so she went into the car to get some sleep. When I returned, she told me that above the passenger side rear seat was leaking (it was raining alot today). Upon checking it out (slightly bending the lining), i saw that water was seeping through the seal.
What's the best way to remedy this problem? Also a suggestion for a temporary fix would be much appreciated (as it is still raining and I have a towel placed between the lining to absorb the water)?
Thanks in advance.
Old Jan 1, 2003 | 06:05 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
If you can isolate the leak, try putting down a bead of silicone. You'll need to make sure it's dry before putting on the silicone.
If you're under warranty, get it over to Acura ASAP. They should take you right in since further damage could occur.
Good luck.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
