Leaks
Leaks
Today I was with my girlfriend today and stopped at my friend's store for a while. Unfortunately, she had been feeling sick so she went into the car to get some sleep. When I returned, she told me that above the passenger side rear seat was leaking (it was raining alot today). Upon checking it out (slightly bending the lining), i saw that water was seeping through the seal.
What's the best way to remedy this problem? Also a suggestion for a temporary fix would be much appreciated (as it is still raining and I have a towel placed between the lining to absorb the water)?
Thanks in advance.
Thanks in advance.
If you can isolate the leak, try putting down a bead of silicone. You'll need to make sure it's dry before putting on the silicone.
If you're under warranty, get it over to Acura ASAP. They should take you right in since further damage could occur.
Good luck.
Good luck.
IBankMouse
Jun 13, 2020 12:53 PM
