KYBs Installed Ride Comfort worse?
yesterday i installed the kybs agx and camber ingalls, took awhile but when done we noticed the the ingalls were against the wheel well so after about a half hour of this i put the stocks back on with the new kybs aGX and test drove it...b4 i set the front kybs to 2 and rear to 4 and tested, the ryde was actually more bumpier then stock..im tryin to get the most comfortable ryde possible..how would i adjust these for comfort? thanks in advance...
oh yeah and wen i took the stock shocks out the right rear shock was blown or fyked up and didnt even kno.
fyi- i have a ground control Ebich kyb combo.
HOOK EM HORNS
well if you had a blown strut and your ride comfort was better than you dont know what a comfortable ride is, i have the rear of my ride at 2 for comfort try that
i actually replace my stock damaged shocks with the agxs but the comfort is a bit more bumpier...how long have you had ur agxs and is oyur ride better then stock?
HOOK EM HORNS
i actually had a blown stock strut as well when i had to replace my struts, but the ride improved greatly,, ive had my agx's for about a year and love the ride. other than the squeaks from the rubber bushings of the camber kit
The movement has started
do have a camber kit? if yes what kind?
Originally Posted by baka_t
Ignalls front, with rubber busings(no squeaks) and 16washers per side in the rear.
yo after reading this post i am debating on weather or not i should install my brand new Ingalls camber kit and brand new Kyb,agx's.... i have an Eibach prokit...ride is real good with stock shocks.... i am just trying to keep my tires from tearing up on the inside..... 19'z are expensive.....SHOULD I JUST GET AN ALIGNMENT AND SEE HOW THAT WORKS?????
Tristate ViP Crew
What kind of front bumper is that? I heard the coilovers give it a bumpy ride so I went with Eibach Sportlines and kept the stock struts and it rides fine. It's bumpy at first but once it settles its all good.
4/8 is the way to roll.
Im No Superman
im hopin to get these shocks for/after xmas.. so 1/2 is the best way to go for the smoothest ride possible? im still tryin to read stuff and learn all i can about suspension.. i need like shocks 101
wen i installed my ingalls it would hit the wheel well, so i decided to put the stocks back on rather then cuttin the wheel well too much work...wat did you do to make it fit?
Selling my brand new KYB AGX's and Ingalls camber kit.....
https://acurazine.com/forums/car-parts-sale-361/fs-brand-new-kyb-agxs-ingalls-camber-kit-160449/
rockyboy
08-04-2024 10:35 AM
rockyboy
01-25-2016 06:00 PM
Inspire08
10-30-2015 04:00 PM
