Which Kit?
Old Mar 5, 2002 | 05:44 PM
WineRed2.2CL's Avatar
Old School Ridin Clean
Which Kit?
My car is cambering and need a kit quickly, i heard of ignalls and sprint.
What do i need to know about them? My car is dropped maybe 2.75 inches around there no gap at all.
i did the search so don't post that issssshhhhh
Old Mar 5, 2002 | 05:47 PM
1StGenCL's Avatar
958 & 991
glad to see you got rid of that 3 foot drop :P
Old Mar 5, 2002 | 09:10 PM
Bdog's Avatar
Not Registered
http://www.gmpperformance.com/produc...amber_kits.htm Try here there are close to you for ordering.
Old Mar 5, 2002 | 11:05 PM
Essarak Huot's Avatar
ingalls kit
Hey dude the ingalls camber kit works great....there alittle bit expansive..but they work great.....you would want to buy the ajustable ones.....let me know how it works out ..... my car is slammed about 3 1/2inches and the kit works perfect!!!!!!!
Old Mar 6, 2002 | 07:01 PM
what degree should i look for, 3 degree adjustment right?
cause some say .5 to 1 degrees and other 1 to 3 degrees?
Old Mar 6, 2002 | 08:20 PM
Bdog's Avatar
Not Registered
See if this helps http://www.ingallseng.com/performance/camberchange.htm
Old Mar 7, 2002 | 08:46 AM
ingalls
hey dude I forgot which but the ingalls make two kinds of kit the one you can adjust and the one you acn't just order the one that you can adjust.....make sure you jet a proper alingementfor your tires......becareful after you install the kit because the steering wheel will pull ........you must get your car alingement asap after you install the kit......hope this will help you
Old Mar 7, 2002 | 10:11 AM
CWEET CL's Avatar
HITTIN' DA SWITCHES DAILY
i think all camber kits are the same i used to have the camber bolts then i went to the camber adjustable A arms " JUST MAKE SURE YOU GET AT LEAST 3 DEGREES ADJUSTABILITY" with a drop like that you will have to shave the inside lip of your fender and posibly cut a hole at the very top of the fender to keep the ball joint from hitting when you hit a hard bump
Old Mar 7, 2002 | 12:25 PM
dcsquirm88's Avatar
I'm happy with my ingalls kit. Try to get around 3.25 degrees of adjustment or more your going to need it. By the way all camber kits are not the same. I had a progressive on my front before the ingalls and even though it claimed 3.25 degrees of adjustment it was not able to correct for my 2.5 inch drop. Spend the extra bucks and get a good kit. Alignment is a must after install. If you are able to find somewhere cheap to do your alignment in Miami let me know. The only place I found that would do it was Miami Chasis and it was like $120 for an alignment and camber adjustment.
Old Mar 7, 2002 | 12:38 PM
senile32nd's Avatar
Apple tech needing a h22a
hey guys sorry to ask a question in you r post but i jsut mailed my check out for a set of nuespeed race spings 2.5 drop and i know i need ingalls front and back but is there any thing else i need to do
oh yeah i am ordering illuminas
Old Mar 7, 2002 | 09:37 PM
dcsquirm88's Avatar
Just install everything and right after you do go get an alignment. Try to find out ahead of time what shop is willing to do a dropped car alignment because most places won't do it (kmart, pepboys, sears, etc...) Good luck
Old Mar 8, 2002 | 02:21 AM
indopinoy's Avatar
very punny....
i had ingalls problems
i know some of u have ingalls on the front.. i have a set i tried to install twice already, both failed. it pushed the arm out to where the inner fender sat on it. maybe bc my car is kinna low...okok..really low.. any help for me would be helpful..but otherwise, im not too big on the ingalls.
Old Mar 8, 2002 | 02:32 AM
dcsquirm88's Avatar
Re: i had ingalls problems
You have to take the whole control arm off, the install it.
Old Mar 8, 2002 | 05:43 AM
indopinoy's Avatar
very punny....
could you explain a little further?
Old Mar 8, 2002 | 11:40 AM
CWEET CL's Avatar
hey indopinoy you have to cut the inside lip of the fender where the a arm hits it at just cut the lip in that area it will look close but it will clear it when it goes up
Old Mar 15, 2002 | 12:10 PM
Are u saying, DC, the kit is to much to do on your own???\
i should take it to Miami Chasis??
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
