just switched to MOBILE 1 Synthetic
I just went to mobile 1 synthetic oil at 38k, shouldn't be any of a problem right? How much will this improve anything, if it even does so at all?
A-CL Post Whore w/N2O
I've run Mobil 1 since it came out! I change the oil about every 7000 mile or so, and I've had no problems (in approx 8 different cars). ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Quick story:
My brother-in-law and I pulled the engine out of his (then later, mine) 1987 Chevy Camaro to rebuild it. To our surprise, everything was within factory specs; even after 220,000 miles on Mobil 1!!!!!!!!![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
We just put it back together, and it's still running today (over 250,000 miles)!!!!!!![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Just use a quality oil filter, and you should be fine!
Quick story:
when changing to synthetic oil after regular oil after a certain number of miles, don't you have to "bleed" the engine first? like, drain the reg oil, put synthetic in, go for a hundred miles or so, then drain that and put in synthetic again? i was informed you had to do this.
that's cool, i only have to change every 6000 miles, yea i'm pretty lazy too, right i think i just got a regular fram oil filter in there, good enough? do i have to "bleed" the engine, or is that just a rumor?
tlac356
10w30 is heavier, its what I use, when your engine gets older it needs a heavier lubrication
at 65,000 I switched from 5w30, to 10w30
if you have nitrous or turbo, 10w30/40 is recomended cause your engine has to work harder
lanechanger
10-13-2015 10:56 AM
xsilverhawkx
09-28-2015 06:51 PM
