Installing clear turn signals
hey guys, help out a newbie will ya?
I got my clear turn signals in the mail today for my 99 3.0, but I can't find the post which explained the install procedure & type of bulbs to buy. Tried a whole bunch of search commands and I've learnt some pretty interesting stuff regarding installing new audio components , but nothing that specifically answers my query
AdiT
AdiT
look inside the black part of the bumper, just next to the corner lens... you'll probably need a flashlight, but you'll see a hole and inside there will be a philips screw... losen the screw and the lens should pop loose.
The bulbs are a 194 for the corner light and the turn signal is either a 7440 or 1156.
Originally posted by Gshock
Anyone have an instruction to re-wire so the side marker in the front and the signal on the side?
thanks
thanks
Is there a way to get the corner light (next to the headlight), the turn signal light and the side marker light (the one next to the turn signal) all to light up when I want to turn on the parking lights? Also, I'm planning on getting some fog lights. Will they turn on only when the headlights are on or when the parking light are on?
The 2 corner lights are on with the parking lights anyway, so the only modification needed is to the turn signal bulb.
If you get the factory fog lights, they will turn on with your headlights... unless you modify the wirring at the switch, thats how they will be. If you add aftermarket fog lights, you can have them turn on whenever you like.
i asked a local speed shop near me, and their answer was if i got the wiring harness from an acura integra, and then ran the power from the corner lights to the extra power wire on the harness...thats what i heard....kinda makes sense when you think about it...
u dont need a new harness or any BS like that ... take the bulbs out of the light there are 2 wires for each bulb cut both wires for each bulb ( make sure to leave enough on the bulb side to reconnect ) then all u have to do is connect the corner light wires to the blinker and the blinker wires to the corner ... there fore the blinker now stays on and the little corner light blinks .... very simple
here a pic http://www.acura-cl.com/forums/showt...threadid=66419
any probs just holla
MaCe
MaCe
mada51589
05-03-2022 08:54 PM
