install of short ram intake
well im installing the intake system on my car even tho its all messed up. right now i unbolted the top of the air box and im stuck now. any where i could get a dyi some kind of instruction? i looked around couldnt find it
never done it on a 3.0, but it should be pretty similar to this
https://acurazine.com/forums/showthread.php?t=171817
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
so im confused. i removed my air filter box, and now im sposed to remove the resonator below the air box? or am i not. i think theres enough room.. but i dont want to take that thing off because it look like a #@&! to take out and put back in lol. also the tubing that goes into the intake doesnt match up, so im guessing i should fabricate some tubes to make it match up?
also there is a plug going into the sensor assv map. its in my way of taking the plastic tubing out. can i unplug it temperaroly(horrid spelling i know)? then put it back in there again after i take the pipe out
(Mid-Atlantic)
(Mid-Atlantic)
thats good to hear. but if i remove it will it have any change in horsepower//sound?
To get that out, you have to jack up the car, take the wheel off, take the inner fenderwell out, etc. It's a giant pain
Take off the top of the airbox, disconnect the 2 hoses going to the stock intake tube, pull off the intake tube, take out the bottom portion of the airbox, put the filter on the new pipe, clamp it down, then take the rubber tube thing and put it on the other end of the intake, put that on the throttle body and clamp down and then attach the intake to the body with whatever screws it goes to...
Or do like I did a LOOOOONG time ago:
Oh and take off that one cover that is covering a portion of the TB.. It is a lot easier to do it that way.
rigged it with a capital N
um the intake isnt really mounted yet but it just looks ghetto...
e 1st intake tube closest to the engine was in the way of the intake so i just tucked it underneath the intake and wrapped it around. i couldnr really take the metal middle part off cuz it is welded to to another pipe which i dont know the purpose of.
every thing looks bolted on i havent fired the car up yet cuz the filter is rubbing against the car and i want to mount and pad the intake so it doesnt rattle. any advice to make this intake look a little cleaner?
you can take that entire thing off and do one of 2 things. Go to a auto parts store and get a foot of coolant hose. I forget the size, but it will run from the engine to the throttle body thus allowing you to take that entire metal piping thing off. Then take the hose that came with the intake and attach it to where that metal piping went (the front head) and to the intake.
Or the second thing is disconnect that metal piping and get the hose to go from the block directly to the intake. Its what everyone does i might add when they dont want to mess with the coolant line.. They just let it lay in the engine bay and it doesnt bother anything or anyone... It just sits there on top of wires and whatever else in below it..
I know its my 3.2, however what you see done is that metal piping removed and the hose going from the front head to the intake...
Sound maybe, hp no
Thats what I did to get mine out. But then again I had my bumper off anyways.. You wont gain or lose anything from taking it off other than about 5lbs.
I got it installed. and after i turned that puppy on i thought
"damn that humming is worse than i thought it would be"
my next project is reducing it into something bearable. i did some searching and ways to reduce it were.
1. air box stuffed with towels
2. removing the resonator (but i also read that it increased humming)
3. wrapping in dyno mat.
4. mounting the sri properly.
5. or getting an extension and going to cai. (i will probably end up doing this)
oh well i havent been able to have the vtec kick in cuz my hood is smashed.. but after i get the car fixed. i for sure will break this intake in
I removed my resonator today and it was a huge PIA getting the box and the tube out. Finally I managed to drop the plastic that was under the bumper (a lot easier than trying to take it out near the tire).
Clips were a breeze to take out (not sure how people managed to break them). I took a total of like 5 out.
Wrapping in dynamat and the other ideas aren't very good. Either secure it correctly, get a k&n filter or switch it to cai
ummm, yeah, wrapping it in dynamat definately doesnt sound good, not to mention the cost of such a thing.......... if you wanna go the dynamat way, have your firewall dynamatted, and then get a dynamat hoodliner, keep that sound inside the engine bay
(Mid-Atlantic)
(Mid-Atlantic)
Dynamat is not really good for high temp applications either, it melts and drips off
And I don't think that someone with "Magnaflow exhaust 2 1/2"piping" would want to make their engine silent anyways.
cycdaniel
12-17-2019 10:58 AM
nanos
11-12-2015 08:41 PM
Abe_Froman
09-16-2015 01:27 PM
