Ignition Retard
Ignition Retard
Does anyone know the name or model number of the MSD ignition part that allows you to retard the ignition on the actual unit with out an external device? Also what do I need for my complete ignition for the (23)......Ignition, Coil, New cap, and wires. Anything that I am forgetting or any of those items not necessary.
Originally posted by dcsquirm88
MSD BTM is the one that allows for adjustment of your timig. You'll also need a coil and some thicker wires than the stock ones. Thats about it.
It only retards under boost and nothing else (not NOS, rpm, etc.)
They reccoment 2 deg retard with 75 shot. I want to do it as safe as possible including adaquate fuel and fire as well as the trans cooler. I have learned in the past with things, it is better to do it correct the first time, instead of half ass, and then having to go back and clean up your mistakes.
23 you can reatard your timing by using a timing gun or light to accurately adjust your timing. Any mechanic should be able to do it.
And Adam you your are suppose to retard your timing according to the zex instruction manual and only use 93+ octane gas (premium).
dcsquirm88...do you use race fuel at all when your at the track. Just wondering how you like it? Also, I have to find some mechanic that can do it I guess. Without buying the redard box. What do you guys think of the MDS SCI?
The f23a is perfect. It handled the shot just great. Never had a single problem with it. I just needed more power so h22 was the next step. If anyone wants to buy an f23a let me know I have one for sale
. I'm sure you'll love how much faster your will be with the 75 shot. Just don't spray off the line or you'll never get any traction. Good luck.
The msd sci is working good for me. I noticed better throttle response and it seems to pull a little harder. Not a big difference but still an improvement. The main reason I upgraded my ignition is because I'll be installing some nitrous later on.
Acura604
20
Aug 5, 2017 12:55 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
