Idling problem!
Idling problem!
When I turn the car on and it's still even in park, the RPMs rise to about 2000-2500 and then drop to 500 or so. It keeps on repeating this and it's pissing me off because I know that's not right.
Try disconnecting the idle air control valve and see if problem is fixed. It may idle real low, but should be stable w/ AC OFF. CEL will come on and you'll need to reset ECU by puling the 7.5A BackUp fuse for 20 secs.
A massive air leak will cause unstable idle. Check PCV hoses for good connection and PCV functioning correctly (rattles when shaken). It should allow air flow one direction and check air flow in other.
Other possibilities are loose vacuum line somewhere.
good luck
good luck
the problem is most likely your idle air control valve. these things get clogged up and jammed up easily, simply remove this piece from your vehicle, throughly spray with carb cleaner to cleanliness, and replace, should work, if not, you have to replace with a new one.
hope this helps u save some $$$
laters.
laters.
i replaced mine a while ago, and i still have the old one.
it probably just needs a good cleaning, but i didnt have time to clean it and put it back in and find out i might need a new one anyway.
if yours doesnt work after the cleaning, i can send you my old one and you can try that.
just pay shipping and maybe youll save 100 bucks
SidhuSaaB
05-30-2020 12:40 AM
4drviper
09-23-2015 09:00 PM
