idle control valve
Old Aug 6, 2007 | 07:49 PM
turtle504's Avatar
idle control valve
i have a 1999 2.3 cl. i left work and started my car and noticed it was idleing a little low.. then all of a sudden it shut off, i was told it was the idle control valve...... so i was wondering if anyone has one laying around or have a motor that has one? thanks
Old Aug 6, 2007 | 08:15 PM
turtle504's Avatar
also i looked on ebay but couldnt find anything for the CL but i know the accords and cl's are compatible.. so i was wondering if anyone could tell me if http://cgi.ebay.com/ebaymotors/Honda...spagenameZWD1V this would work for me. thanks!!!
Old Aug 6, 2007 | 08:20 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Yup, that's for a 2.3 should be the same.
Old Aug 6, 2007 | 10:07 PM
5-speed's Avatar
4x4- fat chicks cant jump
If you dont want to buy a new one, you can try cleaning out your current one first. heres a write up for cleaning the Idle Air Control valve. Its for a different motor, but it should be very similar http://www.cb7tuner.com/vbb/showthre...highlight=IACV
if its not your IAC valve, it could be your FITV (fast idle valve) or PCV valve. good luck
Old Aug 9, 2007 | 10:05 PM
ricardo95's Avatar
I did it, the cleaning that is. pulled my entire throttle body out and took out the IAC valve. Cleaned it and let it dry. works great adn she pulls better now that I cleaned teh carbon out of teh throttle body. someone with a tl or tsx has a write up here somewhere which I sued. And it has pics. not too complucated. u may need a new TB gasket tho
Old Aug 11, 2007 | 12:51 AM
wontonjohnny's Avatar
i found that turning on the A/C is a temporary fix for this stalling problem.
and if your guilty of playing with your throttle cables to remove pedal slack, you might have it to tight... i had this problem and noticed on my safc the throttle% was bouncing around ~.8% when it did the mysterious stalling.
i bet the ecu is having trouble trying to adjust your idle rpm.
i put back a tiny bit of slack and it hasnt stalled since. (2 months ago)
Old Aug 13, 2007 | 09:33 AM
Eo2k1's Avatar
hmm have a link to the thread you used?
Old Aug 13, 2007 | 10:08 AM
F23CL757's Avatar
Fo' SHizzle
Check your ignition swith, might have an issue there. its under recall and Acura will replace for free. Got mind replaced cause my car was stalling about 5 months back. FREE.
Old Aug 13, 2007 | 02:54 PM
it could be either IAC, ignition switch recall or the throttle cable... i did both IAC and ignition switch recall and my car would still stall.... for me adjusting my throttle cable was the fix.
Old Sep 5, 2007 | 12:43 AM
F23CL757's Avatar
Fo' SHizzle
Im now getting low idle and a vibrating idle, not sure if its having something to do with my CEL light (P0420) but my car idles under 500 rpms now. Think it may be the ICV?
Old Sep 7, 2007 | 05:18 PM
qstorm78's Avatar
I cleaned my IAC Valve and now i'm just reving in park after driving for about 20 minutes. I wont rev when i just start only in park after driving for about 20 minutes and when i'm coming to a complete stop. Any ideas?
Old Sep 7, 2007 | 07:48 PM
F23CL757's Avatar
Fo' SHizzle
My RPM's are still droppin below 500 and I cleaned mine. I dont knwo what else to do, and when the fans kick in it really sounds like the car is gonna shut off.
DerrickW
Nov 15, 2015 05:52 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
Brandle34
Sep 23, 2015 07:20 PM
