I love my CL!
Pass the dutchie!
I love my CL!
I've had my CL for 4 day now and I love it. Just got my Pioneer DEH-8500MP headunit installed. Music sounds much better even with stock speakers. It's PIMP BIOTCH!
Pass the dutchie!
Here is a pic of the new headunit.
DEH-8500MP
Is there a special bracket to mount the Headunit with the sunglass holder attached. I dont really like the look of those Plastic Dash kits. I made a custom mount out of 2 kitchen knives and duct tape for now. But a more permanent mount would be preferred.
DEH-8500MP
Pass the dutchie!
I guess thats a no one the custom mount? I guess I will have to engineer sone from some shit at homedepot. I dont really like to think i have kitchen knives holding my cdplayer in.
Pass the dutchie!
No I mean if you look at how the factory cdplayer is mounted in the car the back of the cdplayer is a thick aluminum heatsink and with 2 holes in the back strong enough to support it by that little bracket in there. The trap door in the stock car should attach to every aftermarket headunit if u have that little rectangular bracket around it which every cdplayer comes with, there has to be some bracket sold which allows u to use that mount to attach your aftermarket player too.
Pass the dutchie!
Actually I was thinking about those so called dash trim kits / sticker things. changing the wood to brushed aluminum... but i dont really know much about that product, like has anyone tried them, do they suck?
Honda Technician
Ok, here's the solution without having to use those ghey metra kits which i hate the most (i install over at Best Buy). Get the metal brackets that have holes in them. Make it into a "T" bracket using bolts, etc. Attach that to the back of the head unit and drill the bottom of the T to the backet that used to hold up the factory radio. Now, to keep the radio and pocket together, I used the factory bracket that used to hold the pocket and the factory radio together. A little difficult to explain. Once I get my digital camera I'll take pictures, but it can be done without having to use duct tape (your CD player will probably start to heat up quite a bit) and without using that fucking kit.
Pass the dutchie!
I think I am going to make one out some erector set peices my self. Most of the origional OEM mount is still usable. 2 of those long strips of erector set bent in the form of a U or rectangle 3 sides. Because there are alternatng oval and circular holes the perpendicular piece can get screwed onto the OEM bracket and then the 2 fork like pieces sticking out form a tray for the cdplayer to attach to anywhere on the bottom right in its OEM location. The eyeglass trap door hangs from the cdplayer.
Acura604
2G RDX Photograph Gallery
17
02-08-2021 03:32 PM
