How much should it cost to get our AC recharge?
i bought a large can of r134a for $20, on the can had a website that had video instructions. Couldnt be much easier. I'll get the website once i get home from work. I also recommend getting a charge kit with a gauge so you dont overcharge, which can be worse for the AC
~[ô¿ô]~
You can do it yourself for a few bucks.
Instructions to recharge your A/C.
You would recharge on the Low side. On Honda/Acuras it typically looks like this:
If your AC has declined due to nornally expected losses through hoses and around the compressor shaft seal, a recharge can be done w/ low side gauge very crudely, and you may overcharge the system. Charge w/ engine running a steady 1500-2000 rpm and car in shade.
However, if the reduced AC performance is due to bugs on the condensor, a cooling fan not working, bad expansion valve, weak compressor, etc, you will not get good results w/ a low side charge gauge, and in fact could potentially damage the compressor (overcharge leading to opening of the relief valve which usually won't close completely once excess pressure is released).
BTW, you can't hook up the charge kit to the high side. The connector will only fit the low side connector.
good luck
good luck
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
