How much for boot repair ?
Old Mar 18, 2009 | 05:35 PM
cl-baller201's Avatar
2.2CL owner
hey guys, i feel this cluncking noise when I brake. Its on my left front side. I take the rim off and see that boot is leaking.
how much should this cost to fix ?
Old Mar 18, 2009 | 06:15 PM
hybridnrg's Avatar
...is now Carbon Fiber'd
i would just get a new cv-shaft. I went to my local auto parts place and a new one is about $60 for right and $80 for left or vice versa...either way it came out to be $140 for both sides with lifetime warranty.
I went this way because at the dealer it is $175 each refurbished and $350 brand new each.
Old Mar 18, 2009 | 07:36 PM
Anhedonia's Avatar
Theres a vendor on here who has all oem parts for way discounted.. you could even get in touch with him. i cant think of his name right now for the life of me.. although he had a thread about his parts not too long ago.
Old Mar 18, 2009 | 09:40 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Just get new axles
Old Mar 19, 2009 | 09:48 AM
2.2CL owner
Ok guys so I understand, when I brake I get this bumpin' feelin' on the pedal. Like its hitting something. So i reckon that's def. a boot problem because of the leak i saw when i took of the tire off.
You guys suggest buying new axles ?
Or CV shaft ? ... and what are the difference between these two parts on the vehicle?
also I got the service done on my car from the dealer when i first got it, and they repaired it. Should they be liable for repairs ? .. this was done 4 years ago.
thanks
Old Mar 19, 2009 | 01:09 PM
bigT's Avatar
axle and cv shaft is the same thing. No way the dealer would be liable with it being that long ago. This is considered a regular maintenance thing anyway.
Old Mar 19, 2009 | 01:16 PM
on1wheel01's Avatar
yea like they said just do the whole cv shaft much easier
Old Mar 19, 2009 | 01:31 PM
YL Al's Avatar
quick diy for cv shaft
loosen axle nut (2 ft breaker bar and 36 mm socket)
remove wheel
remove brake caliper and brake bracket
remove the axle nut
remove the ball joints retaining nut
slide knuckle out of upper and lower ball joint and slide it away so that it sits on the
tie rod joint (remove the cv shaft through the hub assembley before sliding away the knuckle)
pry out the cv shaft and install a new one , make sure it sits in the splines correctly
put everything back
Old Mar 19, 2009 | 08:08 PM
2.2CL owner
remove wheel
remove the axle nut
put everything back
i see, thanks for the step by step. how much would a shop charge me for this in labor and cost vs. me doing it myself ?
i have never done this to my car myself.
Old Mar 19, 2009 | 08:26 PM
03CL6MT's Avatar
To get an accurate cost of having a shop do it, you will need to call your local shops and ask, because it will vary a great deal. But I believe it would be safe to assume that by doing it yourself you could save a few hundred dollars, and twice as much if you choose to replace both CV shafts while you're at it (which I would recommend).
A word of caution: If you do it yourself, be sure to loosen the spindle nut before you jack the car up (you'll have to remove the wheel's center cap), as the torque needed to loosen it is sufficient to pull the car off the jack stand.
Old Mar 19, 2009 | 08:55 PM
YL Al's Avatar
probably the cheapest you'll find is 1.5 hours labor or maybe 1 hour, so ur looking at 60-100 minimum for labor plus 60-70 parts for one cv shaft
i remember doing mine for $60 labor at a local mechanic (very cheap)
i was in a hurry and my friend was graduating that same morning so i ran to the parts store grabbed the cv shaft and took it to the mechanic ,he put it in about 15 minutes
in other words u would save about 60-100 buks doing it urself (each side)
Old Mar 20, 2009 | 08:54 AM
2.2CL owner
I would def. wanna do it myself, however this would be my first install of this kind.
I'll see what a shop tells me first. I would rather learn how to do this myself.
Thanks for the advice.
Old Mar 20, 2009 | 09:27 AM
2.2CL owner
Is this diagram accurate of the service i need to do.
http://www.autozone.com/autozone/cat...questid=264050
theres a diagram on the right that shows the work to be done.
Old Mar 20, 2009 | 09:51 AM
Tehvine's Avatar
6spd FTW
I think on the CL's on the driver side we have like an intermediate shaft as well. But it should not pose a problem really. Tools you will need: Ball joint separator (rent or buy from autozone for $10), 36mm Socket for axle nut and a bigass breaker bar or pipe, jacks, stands, and i believe 14 and 17mm sockets, and a hammer and screwdriver of sorts to unstake the axle nut. Oh and don't forget patience with about 2 - 3 hrs of your time if it is your first time. Download this: http://downloads.hondatech.info/Auto...e%20Manual.zip
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
polish_pat
Sep 30, 2015 12:22 PM
jmaxima03
Sep 27, 2015 10:22 AM
