How Many....How Many....How Many..???
Old Sep 9, 2004 | 06:58 PM
Cocoa's Avatar
2600lb CL
How many quarts of tranny fluid does it take to refill your Tranny if you were to flush the bad fluids out completely?
What I am saying, if the tranny has NO fluids in it, how many quarts does it take to fill it up?
Pep boys told me 12 !!!! Is that right? Cause I never put in that much when I did mine, and the dip stick seems so inaccurate due to the shape of it. It tends to come back up messy, so the reading is inaccurate to me. But I believe I only put in like 3-4.
Old Sep 9, 2004 | 06:59 PM
liloj's Avatar
i like orange juice
i thought it was 13..lemme go check my manual
Old Sep 9, 2004 | 07:01 PM
liloj's Avatar
i like orange juice
TOTAL is 7.6 qts.....in the manual for ATF 3.0
Old Sep 9, 2004 | 07:02 PM
liloj's Avatar
i like orange juice
i was way off
Old Sep 9, 2004 | 07:36 PM
baka_t's Avatar
The movement has started
I'd say 8 quarts after a full flush.
Old Sep 9, 2004 | 07:48 PM
Cocoa's Avatar
2600lb CL
Woah, I just went to pep boys and had them check on thier computer (icause i thought 12 was way too much)...and he said 3.1 to be exact.
So what the heck?
So the manual says it takes 7.8 quarts of fluid to fill the tranny? If so, than thatz the number I'll stick with.
Old Sep 9, 2004 | 07:55 PM
baka_t's Avatar
That is after a full drain, a flush will remove more fluid, esp if replacing the filter.
Old Sep 9, 2004 | 08:06 PM
liloj's Avatar
i like orange juice
it says 7.6 Total in the manual..so im guesing that with all fluid
Old Sep 9, 2004 | 08:10 PM
wilp99's Avatar
u cannot replace the filter w/o removing the tranny, and cracking it open. the torque conver holds around 3qts by it self so u will never ever ever get all 7.6qts out of the tranny at one time. ur best bet would be to drain and fill 3 times and that is all u can do. acura hooks up to the pressure ports and back flushes everything, but they never get it all out of the t/c. good luck.
Old Sep 9, 2004 | 08:13 PM
baka_t's Avatar
^Is this the case through all the years??
Old Sep 9, 2004 | 08:31 PM
wilp99's Avatar
unfortunatly yes. years and engine sizes. (2.x and 3.0)
greyfoxrdx
1G RDX (2007-2012)
May 21, 2012 03:04 AM
diamondblues
May 17, 2012 02:39 PM
EVOLICARUS
Jun 12, 2009 10:43 PM
