How do i turn off check engine ?
i was working on my car the other day and i unplugged a sensor that went to my distributor. i forgot to plug it back in and started the car. My check engine light turned on and i turned the car off and plugged in back in. How do i turn that check engine light off without disconnecting my battery since i dont have my radio code ?
Originally Posted by 97Acura3.0CL
you do not need to remove any fuses, just remove the battery cable for lik 15-20 mins and you should be cool
also, what does the radio back up fuse has to do w/ the ecu?
just take out the ecu fuse for a few minutes. drive around after it goes off. if it comes back on again, time to see the mechanic
Originally Posted by rmstoico
ROFLMAO! tell me about it! cheap bastards! the last thing people think to do is the obvious!
Yeah seriously....if you know nothing's wrong just make sure you have the radio code and unhook the battery and fuses like others said for a few minutes. No sense wasting time and money at the dealer. Besides if something is wrong, it will come back on again anyway.
HeloDown
Sep 8, 2015 06:51 PM
