Help: secret weapon intake install question
Call me a if you must, but i have a few questions...
I have a weapon R secret weapon intake
1. What is the smaller diameter (4mm i believe) hose for? where does it connect?
2. The larger diameter hose (10mm) is supposed to be cut in two and replaces the PCV hose and the one connected to it(hard lines and hoses), right?
Thanks for the help guys
I know the smaller one gots on the valve cover. Im not sure where the larger one goes. Ill take a picture of mine tomorrow and throw it up here.
Maybe someone else already has a pic of it.
I got the larger one that goes to the PCV hardline, but im still confused about where the smaller hose goes and if i should even put it on there. Also, the little can thing that was removed under the intake hose had a little thing that says "12 v" and some other things with a bunch of small hoses connected to it... what do i do with that?
Thanks for your help guys
I got it all together now. I called the tech support people and they said to put a vacuum cap over the little hole, so I did. Got some amber bulbs for my corners while i was at it, looks nice. I still dont know what I was supposed to do with that little "12v" thing, so I just left it in there. Sounds nice, didnt drive it long enough before to definitely know how much gain (only had it for a month), but definitely some. Thanks for the help
cycdaniel
12-17-2019 10:58 AM
Abe_Froman
09-16-2015 01:27 PM
