help help help help
Old Mar 5, 2008 | 10:34 PM
Nautsiju's Avatar
help help help help
My car has been acting funny lately. ive been feeling a knocking in the car. i cant pin point the location but its been getting worse to a point that when its being driven it makes almost a grinding noise when the wheel spins past a certain point. its not the cv boot or axle ive checked that. its an awful noise. my dad says i could have hurt the transaxle? i think i damaged my tranny by being so low. you guys woould know better
Old Mar 5, 2008 | 10:41 PM
AznX TL's Avatar
where is....
could be your brakes or your bearings going bad if its not your axles.
Old Mar 5, 2008 | 11:11 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Sounds like your bearings or the axles
Old Mar 6, 2008 | 12:04 AM
Nautsiju's Avatar
some pics i took. i think it might be the cv boot after all. the torn part is connected to the wheel
Old Mar 6, 2008 | 12:13 AM
732xghost's Avatar
yea i was gonna say either ^^^^that or the wheel bearing.
get used to it. thats gonna be happening alot.
Old Mar 6, 2008 | 12:35 AM
asianspec's Avatar
i agree with them. also water in the gasoline can cause knocking also.
Old Mar 6, 2008 | 12:38 AM
Nautsiju's Avatar
so its my wheel bearing?
Old Mar 6, 2008 | 08:18 AM
(Mid-Atlantic)
If you have a torn boot, that sounds like the prob
Old Mar 6, 2008 | 08:27 AM
STL+3.0CL's Avatar
Matt
Is it normal for me to go thru those constantly? It seems I have to replace those every 10-14 months. I think I've had my CV replaced 4 times in the last 3 years.
Old Mar 6, 2008 | 09:22 AM
SwervinCL's Avatar
Nom Nom Nom Nom
CV Boot.
Old Mar 6, 2008 | 11:18 AM
732xghost's Avatar
no its not normal, but it happens. ive been threw just about the same as you. as alignment can help a little. but depending on how low you are its gonna keep happening.
Old Mar 6, 2008 | 08:40 PM
automech's Avatar
6th Gear
I would blame the brake pads and the rotors on it but have it checked to be sure.
Old Mar 7, 2008 | 07:32 PM
Orlando3.0's Avatar
Fast Foward>Rewind>Play
get a new axle, its like $50-75 with a core charge. takes a few hours. theres a write up somewhere. my transmission shop charges like 115 a side, installed.
